MM5450 LED Driver Coding
Hi Josh,
I'm driving 32 LEDs using Jameco's MM5450 chip. Here's the link to that chip's spec sheet.
I want to turn on the LEDs one after the other, serially, completing a loop within a minute. I don't know much about how to code in Spin, but this is what I came up with:
I know I'm supposed to turn on the pins one after the other using outa[noparse][[/noparse]datapin], but I don't know where to do this... or am I already doing that with this code?
What do you think? Will this do the trick?
CON _clkmode = xtal1+pll16x _xinfreq = 5_000_000 clk=1 data=2 'will add data neable later OBJ VAR long LightNum PUB Main dira[noparse][[/noparse]clk]:=%10 LightNum:=TurnLightOn waitcnt(clkfreq+cnt) PUB TurnLightOn repeat 32 outa[noparse][[/noparse]clk]~~ outa[noparse][[/noparse]clk]~ LightBits:=(LightBits<<1)+ina[noparse][[/noparse]data]
1 - Make sure the /data enable pin on the 5450 is low (could be tied always low)
2 - Set the serial data pin high
3 - Set the clock pin high, then back to low ( this lights led 34/35)
4 - wait for 1.875 seconds
5 - Set the serial data pin low
6 - Set the clock pin high, then back to low
7 - wait for 1.875 seconds
8 - Repeat 6 and 7 30 more times
but i tested this out and still, nothing is working. also i connected the data enable pin to ground and i hooked up the the brightness control pin to the power supply. are there any other corrections i could make?
I see no dira[noparse][[/noparse]data] := 1 anywhere, so the data pin is input all the time!?
Pullmoll's Propeller Projects
