Propeller doesn't run code properly on StingRay if not attached via USB
Hi guys,
I am currently working on a project to get the StingRay to autonomously make its way to a GPS location. I have the code up together, it everything seems to work while it's attached to the PC, but when I turn it on and its not connected, it won't get past the first line of code. I have multiple objects and cogs running, so the way to test to see if the code is getting past the first hurdle is to launch the pings straight after:
I've tried enclosing all the instances of serial output in the 'if ok1' statements, but since the cog is actually launching they are true and run anyway.
I think the program is falling over any time there is serial communication without a receiving terminal. Has anyone else had this problem? The parallax search feature doesn't yield any meaningful results.
Also, another interesting feature.. my ping handler doesn't work at all if I remove the serial com object, even though it doesn't use it. any thought?
<code>
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
PING_Pin0 = 0 ' I/O Pin For PING)))
PING_Pin1 = 3 ' I/O Pin For PING)))
PING_Pin2 = 2 ' I/O Pin For PING)))
PING_Pin3 = 1 ' I/O Pin For PING)))
PING_Pin4 = 4 ' I/O Pin For PING)))
FRONTLIMIT = 15
DOWNLIMITMIN = 4
DOWNLIMITMAX = 10
VAR
long stack[noparse][[/noparse]10]
long cog
OBJ
dbg : "FullDuplexSerial"
ping : "ping"
DAT
ping_out long $0, $0
PUB stop
{{ Stop driver - frees a cog }}
if cog
cogstop(cog~ - 1)
PUB start : Success
stop
Success := (cog := cognew(checkpings, @stack) +1)
PUB set(pf, pd)
ping_out[noparse][[/noparse]0] := pf
ping_out := pd
PUB get(pf, pd)
long[noparse][[/noparse]pf] := ping_out[noparse][[/noparse]0]
long[noparse][[/noparse]pd] := ping_out
PUB checkpings | range0, range1, range2, range3, range4, pingfront, pingdown
repeat
pingfront := pingdown := 0
range0 := ping.Inches(PING_Pin0) ' Get Range In Inches
if range0 =< FRONTLIMIT
pingfront += %0001
range1 := ping.Inches(PING_Pin1) ' Get Range In Inches
if range1 =< FRONTLIMIT
pingfront += %0010
range2 := ping.Inches(PING_Pin2) ' Get Range In Inches
if range2 =< FRONTLIMIT
pingfront += %0100
range3 := ping.Inches(PING_Pin3) ' Get Range In Inches
if DOWNLIMITMIN =< range3 AND range3 =< DOWNLIMITMAX
pingdown += %0001
range4 := ping.Inches(PING_Pin4) ' Get Range In Inches
if DOWNLIMITMIN =< range4 AND range4 =< DOWNLIMITMAX
pingdown += %0010
set(pingfront, pingdown)
waitcnt(clkfreq / 50 + cnt) ' Pause 1/30 Second
</code>
I'm either going mad or both...
OBJ
'PINGS
ping : "Ping_Handler"
'SERIAL
FS : "FloatString"
PUB Main | ok1, ok2, ok3, ok4, ok5, ok6
ok1 := dbg.Start(31, 30, 0, 31_250) 'Start serial comms
waitcnt(clkfreq + cnt) 'Pause 1 Second
ok6 := ping.start 'Start pings
if ok1
dbg.Str(STRING("Ping Cog = "))
dbg.dec(ok6)
dbg.tx(13)
<code>
CON
FRONTLIMIT = 15
DOWNLIMITMIN = 4
DOWNLIMITMAX = 10
VAR
long cog
OBJ
ping : "ping"
DAT
PUB stop
if cog
cogstop(cog~ - 1)
PUB start : Success
stop
PUB set(pf, pd)
ping_out := pd
PUB get(pf, pd)
repeat
pingfront += %0001
pingfront += %0010
pingfront += %0100
pingdown += %0001
pingdown += %0010
</code>
This happens for me with the Prop Proto Board USB also, so it's not just a Stingray MSR1 board issue.
Check out the Propeller Wiki·and contribute if you can.
i.e.
http://forums.parallax.com/showthread.php?p=811342
http://forums.parallax.com/showthread.php?p=774972
http://forums.parallax.com/showthread.php?p=651731
