How do I read a string through the serial terminal in Visual Basic 2008?
Microcontrolled
I have a program in VB 2008 that will read the serial terminal and when it gets a string it will search for a web page using the string as the URL. It will then return the webpage. I have successfully sent strings in VB in the past, but I am now having trouble receiving one. Can I have some help on this?
Micro
Check out my new website!!
Use the Propeller icon!!
Follow me on Twitter! Search "Microcontrolled"
Micro
- Stephen
Lots of propeller based products in stock at affordable prices.
@others: I'll post my VB code.
There are several methods. I tend to set a timer going then periodically check if any bytes are available. Put them in an array and then turn them into strings later. Then you have to remember to disable the timer while running that code. This is an incomplete code fragment that sits in a Do..Loop
You can also set interrupts to run when bytes come in. The above assumes that once you have read in n bytes you process them before reading in the next group.
Or am I completely off the mark? I'm not sure what you mean by "through the serial terminal"
www.smarthome.viviti.com/propeller
