Using The Prop Plug on a BS2
··· I was thinking of using the Prop Plug for programming a BS2 on a breadboard. A little confused looking at several Parallax docs. Is the pinout as follows?
·RX = Sout
·TX = Sin
·ATN = ATN
Will the series caps for the ATN signal hurt like in the BS2 super carrier board? When it comes to com signals, I get easily confused by different names.
Also can the Prop be directly programmed with a DB-9, RS-32 like the BS2?
Any Help would be helpful. Don't want to fry a prop or BS2 or prop plug.
Post Edited (Prettybird) : 4/24/2010 6:01:18 PM GMT
·RX = Sout
·TX = Sin
·ATN = ATN
That said, I did make a schematic a long time ago showing how to program a BS2 non-module version, such as an OEM implementation where the RS-232 circuitry could be left out. Those schematics are at the following link. I hope this helps. Take care.
http://forums.parallax.com/showthread.php?p=567989
Parallax Engineering
