How could keep the GPS(GM862) module information in the Logomatic (SD)?
wu4m4n
Hello I am an absolute beginner with basic Stamp
but my desire to learn are much farther away.
What I have is mind is to design a system that can send GPS coordinates of latitude and longitude via GPRS to a remote server, but also have a backup system to store data in a SD because it is very common in data loss via GPRS so keep a backup of the entire journey.
For this I wish to Buy
GM862 Evaluation Kit - Basic 50-Pin
http://www.sparkfun.com/commerce/product_info.php?products_id=479
Stamp Activity Kit - Serial
http://www.sparkfun.com/commerce/product_info.php?products_id=9514
V2 Serial Logomatic SD Datalogger
http://www.sparkfun.com/commerce/product_info.php?products_id=8627
I have read enough about GM862 and how to program in python & AT, which could be able to get the latitude and longitude but that is where my problem begins.
How could keep the information within LogOmatic?
How could forward the information within the SD card?
GPS --- BASIC STAMP - LogOmatic (SD)
GPS ---> GPRS (Remote Server)
LogOmatic - BASIC STAMP - GPS (GPRS / remote server).
Pardon my English but I'm Spanish.
Thank you so much
Thank you so much
purchase them directly from Paralax.
Vinculum data logger:
I found the following
GPS Datalogger
http://forums.parallax.com/forums/default.aspx?f=21&m=379992
GPS Datalogger Kit
http://www.parallax.com/Store/Microcontrollers/BASICStampProgrammingKits/tabid/136/CategoryID/11/List/0/SortField/0/Level/a/ProductID/603/Default.aspx
I was just perfect to start the project.
But GPRS Module What I recommend? consistent with Basic Stamp
Thank electrosys.
I think you have all that you need for your project, by the - GPS Datalogger Kit - from Parallax. This kit is much better and also cheaper, you need only a
GSM/GPRS module.
You could also use a cellphone (an old one maybe) it most be a cellphone with the connections which you could connect to it and send the proper AT Commands. If I find a proper GSM/GPRS module for your project, I will PM you.
Good Luck
Post Edited (electrosys) : 4/25/2010 4:16:31 PM GMT
Internet searching, I found this module.
GM862 Cellular Quad Band Module
Which convinced me, because it has built python, Integrate GPS and GPRS module into one and is compatible with basic stamp.
1 hours ago purchased the following modules in parallex, GM862 least not found it.
BASIC Stamp Discovery Kit - Serial (With USB Adapter and Cable)
Memory Stick Datalogger
Thank you very much for the recommendations.
I ask for help again when I receive products in 6 days more.
I will try to document everything I do, because so he could help anyone else who also is in my same situation for a rookie.
Thank you very much electrosys
