Can you figure this out? Bragging rights to first one to find without cheating.
All resisters are 1 ohm. Bragging rights goes to the first person to find the resistance of this network without using spice or similar simulation software.
Hint answer is less then 2 ohms.
Lots of propeller based products in stock at affordable prices.
I was thinking perhaps removing everything except the bare minimum, then adding on one small section at a time. Then it would be just a series or parallel addition to the circuit?
And with resistors, with series they would double, and parallel they would half.
Or perhaps you could break it down into sections?
(Two one ohm resistors in series would be 2 ohms, parallel .5 ohms.)
Leon Heller
Amateur radio callsign: G1HSM
www.physics.ucsb.edu/~lecturedemonstrations/Composer/Pages/64.42.html
Doing it the hard way one would have to solve a large number of simultaneous equations.
Leon Heller
Post Edited (Leon) : 4/24/2010 4:16:33 PM GMT
john
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
Post Edited (W9GFO) : 4/24/2010 9:40:47 PM GMT
Use SPICE.
Here is the schematic for a SPICE simulation of the cube problem:
www.leonheller.com/Designs/Cube.pdf
The current through the cube is 6A, giving the resistance as 5/6 ohms.
Leon Heller
Post Edited (Leon) : 4/24/2010 10:17:24 PM GMT
Post Edited (MikeK) : 4/25/2010 7:03:14 PM GMT
