New Basic Stamp BOE compatible microcontroller?
I found this on robotshop.ca, it is a chip that looks a lot like the BS2 module and the discription says (i qoute) "Attention all Stamp users! Turbo charge your Stamp project with BasicX!" and "The Netmedia BasicX-24p-u Microcontroller is one of the World's most powerful Basic programmable·Microcontrollers!"·It clamis to be able to run·83,000 instructions per second! (4 times as·fast·as parallax's fastest stamp) and it's only $51! i was wondering·if you could substitue this in the BOE and program it in parallax's BASIC? cause for that price and speed you could make a heck of a stamp balancing bot or a smoother BOE bot (with PING included) URL: http://www.robotshop.ca/netmedia-basicx-24-microcontroller.html·and if it is not possible to program with parallax's software would it at least be compatible with the BOE to the point where you can program it with the BOE?
"When the government is afraid of the people there is liberty, when the people are afraid of the government, there is tryanny"
· Thomas Jefferson
· Thomas Jefferson
If you're looking to upgrade your Boe-Bot, you can use one of the higher-end BS2 modules, like the SX. You can also use one of the proto-boards that Parallax sels either the SX-28, SX-48, or the Propeller. Any of these proto-boards would give you far more instructions per second than BasicX, and both can be programmed in Basic (SX/B & PropBASIC, which are both written by the same person). The proto-boards do require you to purchase a programming "key", but a proto-board + key would cost about the same as the micro that you mentioned.
With the proto-boards you would need to wire/solder your own components, or mount a breadboard, etc.
You'd be MUCH better off using the Parallax stuff. And this comes from somebody who doesn't work for Parallax, who spent a lot of money a while ago evaluating all the 24-pin BS2 'clone' devices.
