PUPPY Prop module for prototyping - now with fast 12-bit ADC/DACs (was Prop Kwi — Parallax Forums
Peter JakackiPeter Jakacki Posts: 10,193
edited 2010-05-04 15:10 in Propeller 1
Normally I don't worry about DIP prototyping modules but I am looking at using a local pcb service for some cheap & quick single-sided pcbs (motherboards) and I thought that if I had a few more smd modules (daughter boards, double-side plated through) then I could knock out some special pcbs and testers real easy. Normally I have used the local pcb service for 5-day double-sided PTH + masks etc prototype panels (large). Anything that I can fit on a large panel I can have for one set price but this usually costs around $400 and actually takes closer to 7 working days. But if I want a simple single sided pcb panel, no masks, then this is much cheaper and can be had in 2 to 3 days.
So if I want a Propeller design admittedly I could use the DIP Props but then I always want the normal EEPROM + crystal etc. Looking at some of the modules I design and manufacture I thought why can't I use this format to mount all the Prop goodies on including caps for the sigma-delta stuff. So that's what I did and in just a couple of hours I have laid out 95% of the pcb, the other 5% will take just as long (or longer). The 3D view looks good but there is nothing like a mock-up when you can do it and I happened to have some blank pcb modules here so I did a mock-up.
Here is a photo of the mock-up with another module in the same format next to it and compared to a 40-pin DIP module as well. I can get 25 I/O + 2 for the I2C plus 2 for the RX/TX as well as the RESET and power, that's 32 pins. I have included a micro-SD, 4MB serial dataflash, RTC with supercap under the pcb, and LDO regulator so I can run it from 3 to 9V easily. There is actually a small area for a PropPlug to go into as well. The QFP Prop is under the pcb.
What do you think, would anyone be interested in these? I will probably end up with far more than I could use so I will make them available assembled.
EDIT: This module is double-sided and plated through and packed with smd goodies (including ADC) just so that I can use single-sided "motherboards" easily.
April 25, 2010 - created webpage for this module at docs.google.com/Doc?id=ddgq8k4b_5gtvcrfhh
This page will be updated regularly.
*Peter*
Post Edited (Peter Jakacki) : 4/27/2010 3:03:48 AM GMT
1024 x 864 - 206K
869 x 406 - 39K
    edited 2010-04-23 09:59
    Thinking about it I realized that having A/D channels can be very handy so I am looking at incorporating a C8051F334 in a small QFN20 for 8-12 channels of 10-bit A/D as I have used these before as smart I2C peripherals with the Propeller. They can be flashed directly from the Prop and I will probably have it doing all the sampling and averaging/min/max etc so all the Prop has to do is read a register. Temperature sensor and UART is on-chip as well. Just got to see where I can route those I/O now.
    *Peter*
  • KPRKPR Posts: 189
    edited 2010-04-23 13:15
    All I can say is WOW... that's an awful lot of goodness on such a small footprint .. what do you estimate you'll be selling them for??
    Kevin
    New ICON coming, gotta wait for the INK to heal, now we have colour!
    edited 2010-04-23 14:21
    Ok, I will probably put a lot of this information online soon but here is a sneak peek.
    KwikProp Specifications:
    • 29 I/O (including I2C and RX/TX)
    • Propeller P8X32A QFP
    • 24LC256 32K byte EEPROM
    • PCF8563 RTC + 0.047F supercap
    • 25VF032 4M byte SPI Flash (or similar)
    • microSD socket - push-push type (unpopulated)
    • C8051F334 peripheral ADC CPU
    • -- 8 channels 10-bit A/D with reference + temperature (P16..P23)
    • -- In-circuit programmable from Propeller
    • LDO regulator 3..9V input
    • 1.8" x 0.8" module
    • Dual 8x2 pins (0.1" pitch)
    • PropPlug interface
    PINOUTS
    |VCC GND        K           P0   P1 |
    |RXD TXD        W           P2   P3 |
    |SDA SCL        I           P4   P5 |
    |RST P24        K           P6   P7 |
    |P23 P22        P           P8   P9 |
    |P21 P20        R           P10  P11|
    |P19 P18        O           P12  P13|
    |P17 P16        P           P14  P15|
    How much? I'm trying to keep the price down but a conservative estimate I'd expect to sell them for around $48 (US) one off.
    Availability? I want them yesterday so I am aiming for protos in 2 weeks and production in 3-4 weeks.
    EDIT: Added revised pcb layout
    *Peter*
    Post Edited (Peter Jakacki) : 4/23/2010 2:33:01 PM GMT
    1231 x 525 - 71K
  • wjsteelewjsteele Posts: 697
    edited 2010-04-23 15:02
    Nice!!! However, I'd upgrade the eeprom to the 24LC512 64k... costs just a few cents more but gives you a lot more useful things you can do.
    Bill
    edited 2010-04-23 15:12
    It's not the cost, the 64K ones are wider and space is tight, but if I didn't have megabytes of SPI Flash and/or microSD I probably would add it. Of course standard width 64Ks will fit anyway and if I can make the wider footprint fit then I will.
    *Peter*
    edited 2010-04-23 16:07
    Amazing, I have actually finished the pcb artwork. It was tight but there it is. All that's left are some final design rule checks, some adjustments then etc and I will send it off fingers crossed for a 5-day proto turnaround. Actually, there will be many hundreds of pcbs as it's just not worth it to get a few. But if there is a problem they will be scrapped and I will have to try again, but I don't think there will be a problem, I have used all these chips in this configuration before.
    *Peter*
    538 x 230 - 22K
  • jazzedjazzed Posts: 11,803
    edited 2010-04-23 16:17
    When I first saw the thread title I thought it said "KiwiProp" .... I agree with Bill and think at least 64K EEPROM is worth giving up something.
    How do your boards connect together?
    May the road rise to meet you; may the sun shine on your back.
    May you create something useful, even if it's just a hack.
    edited 2010-04-23 20:11
    assembly of these boards will be fun. do you have access to pick and place machine or have experience assembling surface mount boards? If not sending me an email squarerootofnegativeone at gmail with gerbers and I can get you a quote.
    Lots of propeller based products in stock at affordable prices.
    edited 2010-04-23 20:25
    Nice layout! One comment in regards to using dual row headers. For prototyping, IMO, it's nice to have I/O pins in a row as opposed to staggered across the two rows. Of course that kicks off many other challenges in regards to trace routing, etc. However, if you install a header, then use a ribbon cable connector to attach to it, your wires would be in order with your I/O pins. So it really comes down to opinion. Also I like having VDD and VSS on each header for prototyping. By making a simple change (trace cut and jumper) on the Propmodule 1x1 I have, I was able to plug in Parallax's uSD adapter directly for my plungelogger This thread has the details.
    If you change to 2x10 headers, you will gain quite a bit of versatility while keeping your module small.
    As far as adding ADC, here's my 76 Guinea Francs... it will be excellent for prototypers using ADC, but will limit the module as a "universal" Kwik propeller module unless you have a way to no-load the chip and have P16-P23 accessible. I can't tell if your header pins go to both the ADC and the prop which would nullify that comment.
    This actually reminds me of my $25 "M44D40" board that I started last year (pic attached). Needs a few finishing touches before it can be put to copper.
    Andrew Williams
    WBA Consulting
    WBA-TH1M Sensirion SHT11 Module
    Special Olympics Polar Bear Plunge, Mar 20, 2010
    115 x 338 - 17K
    edited 2010-04-23 21:24
    I cannot tell from the pcb... did you manage to get the 64KB footprint EEPROM in ?
    Yes, the header would have been nicer to be compatible with other footprints, but as you can all see, the pcb is way to tight for that.
    · Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)·
    · Prop OS: SphinxOS·, PropDos , PropCmd··· Search the Propeller forums·(uses advanced Google search)
    My cruising website is: ·www.bluemagic.biz·· MultiBlade Props: www.cluso.bluemagic.biz
    edited 2010-04-24 03:28
    In regards to the larger EEPROM I can't see the need for it myself although I too think that it would be "nice". But come on, what is 32K compared to the 4M bytes, that's 128 times the extra EEPROM, plus the SPI Flash is much faster. There might be some applications that have been written already that use the extra 32K but any applications that I write will be using the good stuff. Anyway, that's my rationale but I'm always somebody that likes to be flexible, both with people, and in my designs so I haven't made the footprint 100mil wider...................no, instead I found that I can plonk the DFN package which is available right on the same footprint, so there! Now it would be nice if those who said 64K would be nice could speak up and explain their reasons too, I like to think that there is a particular reason. I know some like Microchip EEPROMs simply because they are "nice" smile.gif
    The pins that are labeled P0..P24 are indeed the same pins as the Prop chip itself, hence the label. The ADC pins sit in parallel with P16..23 so no matter what the Prop pins is doing the ADC is running independently and without interference which by the way is very easy to access via I2C with dedicated addresses for each channel (disable feature via an option register). This makes it very fast to access so you only need to issue the I2C device address and read the input that you want in the very next access with any sequential accesses delivering more information on that channel such as the average/min/max etc.
    Sigma delta caps are still in place for P0 and P2 while the feedback resistors can be added externally. The caps won't affect normal digital output switching or even most input signals. Being on the bottom of the PCB they can be removed quite easily with a wipe of a hot iron.
    One of the reasons I chose this pcb format is because I find the 40-pin DIP restrictive plus those poor tracks are routed quite a distance and soak up valuable pcb real-estate that could be used for something other than just copper. Another reason too is that the microSD socket would not fit on a DIP pack but as you can see from the layouts it fits beautifully here. The pcb is designed to be side by side stackable without any gaps and I also have many I/O modules including that 100kHz 10A quad half-bridge module I mentioned in the Sandbox a few weeks ago. I also mentioned my original design that used this module format in
    http://forums.parallax.com/showthread.php?p=791643
    The pinout on this header is not compatible even with my I/O modules because they are very different beasts as the right side is normally dedicated to power switching and the left side to Prop I/O. You can glimpse from the pcb transparency that the Prop pins just flow to the header pins without so much as an excuse me.
    As to the manufacturing of them I don't have any problems as I have had many years of experience with surface mount and these packages etc and I have no problem building the prototypes and initial production myself. If there is enough demand for it then I have people locally that can do pick and place but for these tiny boards I will need to do a run of at least 1,000 to make it economical to cover setups bearing in mind too that reels have quantities like 3,300 chips as in the case of the EEPROM so that's a lot of money upfront which "might" eventually pay for itself but would it be worth the trouble? Keep it simple I say, don't stick your neck out too far, enjoy each day.
    *Peter*
    edited 2010-04-24 08:23
    Since our beloved forum has been spammed I will cover over it in this thread with an update.
    I have added a watchdog function from the PPC to the Propeller. If the Prop activates it then it doesn't go away until the Prop gets reset, one way or another.
    *Peter*
    edited 2010-04-24 15:14
    I have started an on-line document for the KwikPROP which I will be updating regularly.
    *Peter*
    edited 2010-04-25 00:41
    Actually, I like the 64k eeprom because I can load a splash screen and SD boot manager into it. If there is no SD card, I can then optionally load a secondary program with default functionallity from the upper 32k without "wasting" or worrying about fitting it all in the lower 32k.
    Bill
    edited 2010-04-25 01:20
    I see that there will become a standard way of loading other cogs from the upper 32KB. You do however have an SD card which alleviates some of this.
    Where there is space then I see the 64KB version as a no-brainer for minimal cost, but I think size is important for your module too, so 32KB is fine.
    BTW Why did you choose an 8051 overa MC9S08, PIC or AVR? Just asking as I am curious if it has something special or it is because you already use them.
    edited 2010-04-25 03:10
    Ray: I choose the Silabs chip for basically two reasons:
    1) It could fit in the tiny corner due to the 20-pin QFN
    2) I have used them before as PPCs
    I really wanted to use the new LPC111x chips as they are cheaper and faster and a full 32-bits but they just wouldn't fit.
    The way I use 32K of EEPROM in some systems is to lock in a bootloader that reads from the serial Flash and/or the SD card for an autostart file. I can reload the firmware reliably via various methods and always have my own bootloader that I can count on. This means that during development the Prop tool just loads the EEPROM as normal but once testing is done the EEPROM holds the bootloader which loads in the application from serial Flash or SD (both very fast methods) and it can receive new firmware from the SD or other communications links.
    If it were an absolute minimal system without these other chips then a 64K EEPROM would make a lot of sense. However, I did say that I would use the 64K devices but in a DFN pack so that they would fit but not at the expense of compromising the design. It turned out that the common serial Flash chips were also wide so I had to make an adjustment to the artwork for this but fortunately there was a tiny bit of room in this part of the pcb. If it were a choice to have a wide footprint for the 64K EEPROM and no serial Flash then I would not take that course, but rather emphasize the on-board memory capacity of the serial Flash. You can't rely on the microSD as that can be removed, but the serial Flash is always there.
    @Bill: Wouldn't the 4M bytes of serial Flash allow you to load in umpteen splash screens and be able to read out much much faster than a slow 400kHz EEPROM?
    *Peter*
    edited 2010-04-25 09:11
    Thanks Peter. I wondered if it might be size. I saw the 8051 was tiny - don't sneeze LOL.
    I too have a boot loader but it only boots from the SD card - with my setup, there is no point to not have a uSD.
    What you have is a nice small module so we will see how it goes. You have your own use for it anyway.
    edited 2010-04-25 13:47
    You know... I totally missed that there was 4M flash on board. Nevermind the 64k eeprom. wink.gif
    Bill
    edited 2010-04-26 10:56
    The online datasheet has been updated with a schematic for those who are interested. Ignore the value of the sigma-delta caps as they will probably be around 1nf (102).
    There is no room for anything else on this pcb but I did manage to squeeze in the RX/TX lines from the PPC chip so that this can actually form a fully-buffered cogless serial channel accessed through I2C. Decoupling caps are evenly distributed and have very short and generous paths to the chips.
    I am wondering whether to load these modules with 6MHz crystals to take advantage of both overclocking plus USB support. The I2C lines are shared with SPI as only one device will be used at a time so there is one cog that handles the SD card, the Flash, the EEPROM, the RTC, the PPC, plus any other external I2C device. It is possible for the PPC at boot to load up the EEPROM directly from Flash or SD then release the Prop reset thus making the autoload feature completely transparent to the Prop itself. Alternatively I will probably have a bootloader sitting in EEPROM when this device is not in development mode so that it can decide whether it will run software from the Flash, or the SD etc.
    Any feedback is welcome and although I could add improvements to the schematic easily it is a different story trying to route that on the pcb. I will be sending the artwork off tomorrow. Now the sneaky embedded fine print: I will be giving away three of the fully populated and assembled prototypes. If you have an application for one of these modules and this giveaway interests you then drop me an email and tell me a bit about how you would use it and I will select three of these that I think deserve it and the first that you will know of it is when you receive your module in the mail around mid May. I may even be inclined to select more than three, don't we just love this forum(?)
    *Peter*
    Post Edited (Peter Jakacki) : 4/26/2010 2:23:01 PM GMT
  • AribaAriba Posts: 2,697
    edited 2010-04-26 13:54
    Peter
    It looks like the 5th pin of the PropPlug connector is for the 5V supply. I've done this also in the same way on many of my little boards. This lets one supply the boards direct from the USB, with a special PropPlug that brings the 5V from USB direct to this 5th pin.
    But I'm a bit concerned about this other usage of the 5th pin, suggested by Bill Henning, and implemented also on the GadgetGangster SMD Propeller platform board. They feed 3.3V to the PropPlug over this pin.
    You can imagine what happens if a PropPlug with a USB voltage is pluged in a connector that feeds 3.3V....
    I think we need some standard here. One solution can be to use a 6th pin for the 5V supply.
    Andy
    Edit: picture attached
    Post Edited (Ariba) : 4/26/2010 2:06:04 PM GMT
    79 x 106 - 483B
    edited 2010-04-26 14:43
    The 5th pin is to allow the module to be powered via USB as this pin goes to the input of the regulator so it is not possible to power an external adapter via this pin. On some designs I have a dual row of 4 pins with the bottom 4 the same as the Prop Plug and of course I have my own version of that. The upper 4 pins included +5V input as well as I2C plus an spare pin. But lately I have been changing over to a simple 5-pin header compatible with the Prop Plug.
    I don't quite understand why anybody would be feeding 3.3V to a Prop Plug unless it has something to do with getting around the phantom power problem.
    *Peter*
    Post Edited (Peter Jakacki) : 4/26/2010 2:48:35 PM GMT
  • SapiehaSapieha Posts: 2,964
    edited 2010-04-26 14:56
    Hi Peter Jakacki.
    5 pin 3.3 on SerPlug are used to feed it with power suplay that is needed for SP/MAX 3232 IC.
    Regards
    Ps. Look on SerPlug thread for details
    Nothing is impossible, there are only different degrees of difficulty.
    For every stupid question there is at least one intelligent answer.
    Don't guess - ask instead.
    If you don't ask you won't know.
    If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
    Sapieha
  • TubularTubular Posts: 4,774
    edited 2010-04-27 00:26
    Peter,
    Congratulations on a great little design. What you have onboard is a very potent combo. 12 months ago I would have been interested in using it in a commercial product - if it had 12 bit adc (slightly larger 5x5 DFN though). Here's my 2c:-
    1) Your stated goal of having simple single sided motherboards is a good one. But bringing the 3v3 rail out to the motherboard would save having to have a second regulator for the majority of applications that don't need more than a few mA
    2) Andy's suggestion of 6 pins is a great way to achieve this
    3) Is there a reason why the prop plug connection is off the 0.1" grid of the DIL beside it? Shrouded header? Why not go for 3 rows by 8 pins all on a 0.1" grid for flexibility as sometimes the header will need to be brought out via the motherboard, and triple row headers are readily available
    4) Got a power led on there? Gotta have a power led to boost sales
    Looking at it from a '8051 viewpoint, it looks even more attactive. A 8051 with tv/vga processor on the back. I wouldn't be surprised if you find more people from the 8051 world adopting it than the prop world.
    tubular
    Post Edited (Tubular) : 4/27/2010 12:36:54 AM GMT
    edited 2010-04-27 00:49
    More people from the 8051 word adopting it than the prop world? What are you saying man, good grief, what are 8051 people doing on this forum, traitors! smile.gif
    You know that this little puppy (hmmm, maybe I'll call it Puppy Prop instead!!!) is really stacked and maxed but I will see if I can fit an LED into it, one of those little 0603 jobs. I normally put one on my main pcbs and I was going to put one on this module but I forgot (shoot me).
    I understand about bringing the 3.3V out especially when you only need a trickle as I have found myself in that situation before. But there is the other side to consider too and that is ensuring that the CPU fed it's own power that's unaffected by other chips either by noise or by over-current conditions. Bear in mind too that this regulator is a small SOT-23-5 pack and you wouldn't want to be drawing too much more current out of it even though it is rated for it as the power dissipation of the package wouldn't really be up to it and there is no room for larger packs. I could extend the Prop Plug header as you suggested though but it's a really tight squeeze as I would like to keep the width of the pcb (0.8") as it is so that it matches my other I/O modules and is stackable. Let me think about it.
    BTW, the Prop Plug "connector" wasn't going to be loaded as I would have pins pushed into my Prop Plug cable to sit in the holes during programming. The connector is an "extra" put there for convenience really for use on matrix boards as a motherboard pcb would bring this port out permanently either as RS232 or USB.
    12-bit ADC??? Yeah, I know, if only I had the room!! I could do a version without the flash and then I might be able to fit it in. I will think about it as well or I could just get some Puppy Prop prototypes rolling in the meantime.
    EDIT: I am looking at maybe using a C8051F351 or 353 which are 28-pin 5x5mm packs with either 16-bit or 24-bit 1ksps ADCs. Not so fast but maybe the resolution is better to have. The flash I can cram in using a DFN package. Opinions?
    *Peter*
    Post Edited (Peter Jakacki) : 4/27/2010 2:15:03 AM GMT
    edited 2010-04-27 02:16
    The more I think about it, the more I think its really essential to bring the 3v3 out of your module. You're bringing out i2c and the pullups are on your Puppy Prop, so it makes external i2c bus easier. You've already got so much on your board that any external chips are likely to be few (and hence not that much current draw). Being a linear reg you can always supply it with a lower voltage for lower heat.
    Upon searching some more there do appear to be 12 bit ADCs available in a 4x4 DFN, eg c8051f530/530a. The power pins don't seem to be compatible with the 334 however (at first glance anyhow)
    I wasn't proposing to change the width of your board, just seidle the prop plug up against the 16 pin DIL so its all on 0.1". It looks like its off by 25 mil or so in the X direction, on that earlier rev you posted.
    Re the 8051 techs, you would really need to advertise this over on those forums. I don't think 8051 types venture too far smile.gif But I believe they would see merit in it.
    Puppy Prop has a certain catchiness to it. I for one prefer it over KwikProp (or kiwiprop!)
    edited 2010-04-27 02:38
    Wow, I just came across the C8051F411 which is in a 5x5mm 28-pin QFN and available. It has 200ksps 12-bit ADC, two 12-bit DACs, and get this, an RTC with an external crystal. This can replace the PCF8563 I think. I will look more into this now and just hold off any commit at this stage.
    Puppy Prop it is! Good boy, go fetch!
    *Peter*
    814 x 487 - 101K
    edited 2010-04-27 04:54
    Peter, I really hate to throw this in as well, but have a good look at the C8051F912? It also has the smaRTClock and 12 bit ADCs (75ksps instead of 200), and is in a 4x4 (24 pin) DFN.
    I think that 75ksps speed is fine since your competition is the MCP320x, which does 50 ksps at 3v. Also the cost of the F912 is about the same as the MCP3208, but about 30% less than the F413.
    The F912 has some other interesting features - the ADC can also do 10 bits at 300ksps, and it has a dc/dc converter than might be able to drive 20mA off a single AA cell, that would be enough for booting the Prop (though not much else??).
    Now what to do with that real estate you've freed up...
  • Nick McClickNick McClick Posts: 1,003
    edited 2010-04-27 05:41
    I've been using this 64kb eeprom for the Propeller Platform and Pixter. It's $1.70. I can't tell if it's the same footprint as your board, though. fwiw.
    Propeller Forums RSS Feed!
    Gadget Gangster - Share your Electronic Projects
    edited 2010-04-27 05:42
    Well tubs (can I call you that?), I got to thinking about the F411 and it is a mighty beast that would make the 8051s of yore faint at heart. I know that I can make it emulate an EEPROM fully including the boot EEPROM. By connecting the Flash chip to it rather than to the Prop I can simplify access to large amounts of I2C memory by emulating the 64K EEPROM at it's address of $A0 and then emulating a special 64K EEPROM at $A2 that is paged through another address. With a 4MB flash I can emulate up to sixty-four 64KB EEPROMs!!!!
    So the Prop ends up talking to the PPC for boot data, general EEPROM data, RTC, Analog, watchdog, spare serial ports etc. Isn't that a powerful combination? The user doesn't have to worry about 8051 code because it appears as a normal I2C chip, especially when it's accessed as EEPROM, but those who want to dabble can. The RTC access would be in binary or ASCII string mode as that's the way I find my application wants to use it. Bear in mind too that the F411 can run the I2C bus at over 1MHz so the Prop could take advantage of this too. There is a possibility too that the PPC can override the Prop's crystal and clock it directly allowing us to use a standard crystal on the Prop but for special applications it can switch to those odd frequencies but that's something that I will play with.
    The RTC and EEPROM are now removed and the flash stays along with the F411. The fact that the EEPROM is emulated is transparent to the Prop, it just boots as normal.
    All this is going to delay the prototypes a few more days but it'll be worth it.
    *Peter*
    edited 2010-04-27 05:49
    Nick McClick said...
    Thanks, I checked it out and that particular one is the standard width, they are available, and they are cheap and fast (1MHz). I will keep these in mind for other Prop products but as you can read from my previous post I may not bother with the Puppy (unless it fits).
    *Peter*
