Encoder reading accuracy
Hi All,
I am using Quadrature Encoder object from OBJEX. I use it link to a Auagro HEDL 5645 optical encoder.· I have problem of reading accurate··value. There is about 0.3% to -0.3% different of reading.·· Is there any one else use this object?·· what is your result?··· Or onyone could suggest something I could reduce error?
Ok, there seems to be an integrated driver, so no need for pull ups?
cmapspublic3.ihmc.us:80/servlet/SBReadResourceServlet?rid=1181572927203_421963583_5511&partName=htmltext
Hello Rest Of The World
Hello Debris
Install a propeller and blow them away
Post Edited (ErNa) : 4/23/2010 6:14:23 AM GMT
I really can't see how you can quantify the error in this way, the system is digital and it will either work or not, if it doesn't then the error will grow and grow as the encoder is incremental. Errors are more likely to be mechanical or simply a manifestation of the resolution.
Graham
I use Propeller drive a stepper and read position by using encoder. the reading of drive position and enocder position is not same at all. the encoder reading also change everytime when I repeat same driving distance. Maybe it is singinal problem. I am check this out now. Anyone can suggest anything else could cause my problem?
Graham
I find the problem is reading differencial to ttl. I need make a board to convert differencial to TLL. that is working now.·
HEDS-55xx/56xx series encoders are widely used in·industrial contol and servo motor.·It is good thing to have prop work with it
