GPS_Float Object - which method is best to calc short distances between two poi
LarryG
My project is a computer for my bicycle. I am really enjoying learning SPIN and reading many of the posts here. One main function of my bike computer is GPS. The guys I ride with inevitably want to take a shortcut back home, and we end up riding an extra 20 miles around farmlands of Ohio. No matter where I am I will have the bike computer point toward home with an arrow, and tell me the distance to get back home (as the crow flies). (And I think I am better off following a randomly flying crow than my buddies when it comes to getting back home [noparse]:)[/noparse]
GPS_Float looks like the hot ticket for this function. But I don't know much about navigation and am looking for advice. Knowing I would typically be traveling a max of 100 miles from home, what method is best to determine distance (and bearing) to home? Is it the Float_RhumbL_Dist method, or should I focus on the Great Circle methods?
Thanks for any input.
Larry
Larry
If you are interested in the formulas check
williams.best.vwh.net/avform.htm
and
www.movable-type.co.uk/scripts/latlong-vincenty.html
You could also use planar cartesian projection...
Massimo
Style and grace : Nil point
mathforum.org/library/drmath/view/55417.html
I am a newbie to all this great circle stuff, but it is amazing and it has been making me dig up a lot of math I haven't used in years.
Andrew Williams
WBA Consulting
WBA-TH1M Sensirion SHT11 Module
Special Olympics Polar Bear Plunge, Mar 20, 2010
