Propeller with SPI for NRF24L01
I use propeller with NRF24L01 but i don't know about SPI for configure module NRF24L01
Can I should
Post Edited (samurai) : 4/22/2010 11:40:01 AM GMT
Can I should
PUB SpiReadWrite(byte_out) : byte_in | bit
SPI read-write procedure (8-bit SPI mode 0)
Read and write are synced, i.e. for each byte in it is one byte out
For deatails see: [url=http://en.wikipedia.org/wiki/Serial_Peripheral_Interface_Bus]http://en.wikipedia.org/wiki/Serial_Peripheral_Interface_Bus[/url]
byte_in := byte_out
repeat bit from 0 to 7
'Write MOSI on trailing edge of previous clock
if (byte_in & $80)
High(SPI_Mosi)
else
Low(SPI_Mosi)
byte_in <<= 1
'Half a clock cycle before leading/rising edge
TIME.PauseUSec(1)
High(SPI_Sck)
'Half a clock cycle before trailing/falling edge
TIME.PauseUSec(1)
'Read MISO on trailing edge
byte_in |= Read(SPI_Miso)
Low(SPI_Sck)
return byte_in
PUB SHIFTOUT(Dpin, Cpin, Mode, Bits, Value)
dira[noparse][[/noparse]Dpin]~~ ' make Data pin output
outa[noparse][[/noparse]Cpin] := ClockState ' set initial clock state
dira[noparse][[/noparse]Cpin]~~ ' make Clock pin output
if Mode == 4 'LSBFIRST
Value <-= 1 ' pre-align lsb
repeat Bits
outa[noparse][[/noparse]Dpin] := (Value ->= 1) & 1 ' output data bit
PostClock(Cpin)
if Mode == 5 'MSBFIRST
Value <<= (32 - Bits) ' pre-align msb
repeat Bits
outa[noparse][[/noparse]Dpin] := (Value <-= 1) & 1 ' output data bit
PostClock(Cpin)
PUB SHIFTIN(Dpin, Cpin, Mode, Bits)|Value
dira[noparse][[/noparse]Dpin]~ ' make dpin input
dira[noparse][[/noparse]Cpin]~~ ' make cpin output
Value~ ' clear output
if Mode == 0 'MSBPRE
repeat Bits
value := (Value << 1) | ina[noparse][[/noparse]Dpin]
PostClock(Cpin)
if Mode == 1 'LSBPRE
repeat Bits +1
Value := (Value >> 1) | (ina[noparse][[/noparse]Dpin] << 31)
PostClock(Cpin)
value >>= (32 - Bits)
if Mode == 2 'MSBPOST
repeat Bits
PreClock(Cpin)
Value := (Value << 1) | ina[noparse][[/noparse]Dpin]
if Mode == 3 'LSBPOST
repeat Bits + 1
PreClock(Cpin)
Value >>= (32 - Bits)
return Value
Leon Heller
Amateur radio callsign: G1HSM
