Object for reading a config file - and other magic ... — Parallax Forums
MagIO2MagIO2 Posts: 2,243
edited 2010-06-01 18:50 in Propeller 1
Hi there ...
I think this might be a problem which can occur in other projects as well. Here is the first working draft of my solution. Next few days I will change it and make an object out of it, so, please don't put to much energy in this version·and don't·use it as is in your projects. The changes will be to big. But maybe someone is interested and maybe has some ideas I did not think of.
The demo only requires a SD card and a serial terminal. Copy the desk2.ini to the SD-card. If you start the program you have to switch to the terminal and press any key two times. Then you'll see the output.
Post Edited (MagIO2) : 4/25/2010 6:22:13 PM GMT
  • MagIO2MagIO2 Posts: 2,243
    edited 2010-04-24 13:13
    Making progress in morphing the config-file-reader into a object.
    Did someone try out the posted code? Some comments? Ideas? Is there a MUST HAVE before realeasing to the ObEx?
    One more idea ... this little config reader can also be used as a scripting engine. Could be usefull for one or the other problem.
    edited 2010-04-24 19:56
    **** solved **** but I don't have an explanation why it works in the first post and it does not work here
    Need someone who has an eye on the code. I tried to transform the code of my first post into an object. But somehow it's not doing the same thing as before even if I don't see a change in the relevant code.
    "Tried to load outside of buffer!" gives a hint where things go wrong. Loading and processing the first 512 works fine, but loading the next part of the config-file is doing something wrong. The bytemove seems to copy the remaining part of the buffer to a wrong place.
    Thanks in advance for everybody who's gonna have a short look
    **** thank's again for the downloader - I'm gonna add some comments for docu and put the result to the ObEx the next days. This bug would really make a good challenge.
    Post Edited (MagIO2) : 4/24/2010 10:36:54 PM GMT
  • JonnyMacJonnyMac Posts: 9,806
    edited 2010-04-25 16:08
    @MagIO,
    I tried the first version and was initially puzzled because nothing happened. After verifying that my SD card worked (using the FSRW test program) I dug into yours and found that to get going I had to press several keys. I made your demo a little more "JonnyMac (i.e., regular guy) friendly" by changing the second line in CogOS_IO.start to kb.rxflush, and then modified the starting section of the main program like this:
    pub main | sz, ln, oldln, rd, aofs, badr, i, ti, pc
      term.start( 0,0 )
      waitcnt(clkfreq >> 4 + cnt)
      term.str( string( "ReadConfig test",$0d ))
      term.str( string( "-- press a key...", $0d, $0d ))
      term.rx
    Like you, I'm interested in having a little script reader that I might be able to use for a simple animation controller (for Halloween and movie prop control).
    Jon McPhalen
    Hollywood, CA
    edited 2010-04-25 17:00
    I bet I mentioned somewhere in the comments that you have to push some buttons to get it started ;o)
    Yep .. scripting is exactly what you can easily do with it as well. Wait a few minutes, I'm nearly done with the version I'm gonna upload to the object exchange.
    edited 2010-04-25 17:42
    Added the ConfigReader to the ObjectExchange. You can find it in Tools.
    edited 2010-04-25 18:51
    MagIO2 said...
    No mention in the program comments -- I had to dig through the code. In the future, you'll probably get more feedback when you ask for it if your programs are easier to work with (i.e, they actually do something when you start them, without requiring unspecified user interaction). When a program runs and nothing happens, many assume it doesn't work and toss it; I nearly did.
    Jon McPhalen
    Hollywood, CA
    edited 2010-04-25 19:02
    Oh .. ok ... did not mention it in the code, but in the first post.
    I'm going to change it in the archive I put to the ObEx. Thanks for your feedback.
    edited 2010-06-01 07:05
    Ok ... 30 downloads so far ... so tell me, what do you use the ConfigReader for? ( Or why you don't use it :-(
    Here's my story:
    I currently use it as a script-language interpreter. I still want to build a remote control replacement* for my livingroom which uses a graphical touchscreen display. As I definitely want to have a nice GUI, the graphics for animations needs to be pre-calculated. So I defined some instructions which allow to set the background and do simple slide-in/-out animations for example for the tool-bar or a window ... maybe blending in and out will be added as well.
    So, the ConfigReader is currently used to read all this instructions and render the pictures needed out of a set of TIFF-files. This way I don't have to prepare the whole images with a graphics-software by hand. This also allows to change the skin from time to time. And the result is stored in one huge vMem-file, which is much better than my first attempt, where I ended up with a lot of files.
    Later on it will also be used to read the button positions and propably all other settings needed. This way the settings can be kept in a nice text-file which can be easily extended/modified.
    ..... modified .... that reminds me ... where is CassLan???
    * hopefully remote control replacement is a understatement. In the end it rather should be a home automation central ;o)
  • KyeKye Posts: 2,200
    Specific purpose stuff doesn't get alot of downloads... Don't be sad about it. As long as you have what you need its all good.
    Nyamekye,
