Woah is me: SX28 Failure Snippit
Just a little personal story to share...
Well, here I was, having a couple hours and in the right frame of mind to do some coding on my project with my sx tech board.
Things weren't·working well... I tried some known working coded, and still no dice.
I notice that my status led...instead of turning on/off, it goes on, and dims.
Examined code, take off my aux breadboard, check for shorts, etc. nada.
Double checked my code, then eliminated everything except code for pulsing·the led.
Still... On/Dim...On/Dim.
Measureing the voltage 5V on, 2.5 Volts off - Man, wondering if·eletronics is really for me?· What's going on?
Turns out all the pin showed 2.5 volts!···
I was thinking I had some stray AC voltages from somewhere -·isolation proved nothing.· (In another related 'why me' story,·i was able to magically turn on an LED by touching·the wire instead of the·piezo film.· Turned out I had been placing my foot on my·KVM switch, which had·some sort of AC signal from it impacting the circuit.· That took a bit of time·to·figuring out!)
Well, lucky I had another sx28 and popped it in, and all worked great!
Not sure what happened.· Must've been some sort of static issue or something - i've never had that happen to me·before.· It always just stays on my desk.
What's facinating about this foir me, is that it only did it when it had a program uploaded, and the program (at least the led part)·essentially still worked, althoug it wasn't truely off. .·
I guess something happened in the output stage of the SX.
I guess I'll be ording a few more SX28's.in the near future!
So much for my time on this tonight.· Just thought I'd vent and see anyones thoughts.
Thanks for listening!
Robert
Thanks for your post, and I agree.
LED is essentially RB0 to a 330 ohm resistor to the LED to VSS (Gnd)
I used SX/B, and the· I/O was set up in code·to be:
LED Pin RB.0 Output
Would have never thought it was the micro - esp. all pins!
Hmm,· maybe I can now sell this chip as an April fool's gag!
