[noparse][[/noparse] Variables ]
result VAR Word
true CON 1
false CON 0
index VAR Word ' Counter For Ramping
counter VAR Word
DO : LOOP UNTIL HB25 = 1 ' Wait For HB-25 Power Up
LOW HB25 ' Make I/O Pin Output/Low
PAUSE 6 ' Wait For HB-25 To Initialize
PULSOUT HB25, 750 ' Stop Motor 1
PAUSE 1 ' 1 mS Delay
PULSOUT HB25, 750
Main:
DO
GOSUB POT_READING
DEBUG DEC result, LF
'ruleFired = false
Rule1:
IF (result < 2112) THEN'AND (ruleFired = false) THEN
PULSOUT 12, 650
GOSUB RIGHT
'ruleFired = True
DEBUG "rule 1 ",CR,LF
ENDIF
PAUSE 200
'Rule2:
' IF (result > 2112) THEN'AND (ruleFired = false) THEN
We are using 2 HB25 motor controllers one for the drive motors and one for the steering motor . We followed the RC time circuit example and used a potentiometer to track steering position. The major difficulty we are having is trying to get the motor to turn to a center position( or any position for that matter) that corresponds with the potentiometer.
Might I inquire as to why you are using HB-25 controllers for Servo mtors? Seems to me a Servo PAL would serve the same purpose and are less expensive and you could use the H-25 for DC motors. Just curious!!!
I misspoke I am using a worm gear dc motor from a car seat. the reason for using it was it attaches easily to the shaft. However as the project has moved forward I am finding that there are better choices that make it easier to track position.
- Stephen
·· Can you post the program that you sent me on the forums? Are you using 1 or 2 HB25 modules?
Respectfully,
Joshua Donelson
www.parallax.com
result VAR Word
true CON 1
false CON 0
counter VAR Word
PULSOUT HB25, 750
Main:
DO
GOSUB POT_READING
'ruleFired = false
Rule1:
PULSOUT 12, 650
GOSUB RIGHT
'ruleFired = True
ENDIF
PAUSE 200
'Rule2:
' GOSUB Rightcenter
'ruleFired = True
' DEBUG "rule 2 ", CR, LF
' ENDIF
' PAUSE 200
Rule3:
PULSOUT 12, 650
GOSUB left
'ruleFired = True
DEBUG "rule 3 ", CR, LF
ENDIF
LOOP
'SUB POT READING'''''''''''''''''''''
POT_READING:
HIGH 7
PAUSE 200
RCTIME 7,1,RESULT
DEBUG ? RESULT
'GOTO POT_READIN
RETURN
'SUB TURNE RIGHT
Right:
FOR counter = 1 TO 100
PULSOUT 14, 650
PAUSE 20
NEXT
GOTO MAIN
Left:
PULSOUT 14, 850
PAUSE 2
NEXT
GOTO Main
forward:
DO
PULSOUT 12, 650
PAUSE 20
LOOP
END
Rightcenter:
PULSOUT 14, 760
PAUSE 2
NEXT
