PINK Firmware Released (The future of the PINK module)
Hello everyone,
As of today we are making the firmware for the PINK module available so that customers may update their own existing modules.· This is happening for several reasons:
The developer of the firmware (NetBurner) will continue to·update the final versions of the firmware to repair any bugs we or customers may find.· The updated firmware will then be posted on the forums and eventually the product website.· There are two versions of the firmware being posted.· Please read the notes below for each version before downloading them.
UPDATING YOUR FIRMWARE:
You should receive a message box that the update was successful (no errors).· Please note that the firmware file must be stored outside of the ZIP file for this to work and the filename should not be changed.
CURRENT FIRMWARE VERSION: V1.35 (OFFICIAL)
The official current version of the firmware is V1.35 and has been tested for errors, however we cannot anticipate every situation in which the PINK modules are used.· Therefore if you encounter what you believe to be a bug, please post a message in the forums so we can determine if there is an issue and perhaps try and duplicate the issue ourselves.· Other members can also report of they have or can duplicate the same issue.
BETA FIRMWARE: SSL SUPPORT (04-20-2010)
This firmware contains SSL support and programmable SMTP port number.· However it is not supported by Tech Support.· All questions should be posted here.· This version of the firmware is a Beta release with customer feedback driving any bug fixes.· So if you're interested in the SSL support you can test this beta version and report any problems here.· We will have the bugs updated in as timely of a manner as possible.· As revisions are made I will post revision history below.
Parallax Engineering
- Changes in ISP infrastructures are forcing us to have to keep updating the firmware to make the modules compatible with ISPs such as non-standard SMTP ports and SSL requirements.
- Parallax does not handle the development directly, but rather this is done through a 3rd party.
- Until today customers have had to send in their PINK modules to have firmware updated putting extra resource drains on both Parallax and customers.
- There is currently a Propeller-based Web Server solution in development for which Parallax and/or customers will be able to customize firmware due to the open-source nature.
- Your PINK Module must be able to be seen by the IPSETUP program.
- If IPSETUP detects the PINK Module then run AUTOUPDATE.EXE (this program is included on the CD that came with your PINK kit).
- Select the PINK Module you wish to update.
- Select the firmware file you wish to use.
- Click the update button.
· Thanks! That is good news - I updated my firmware from 1.33.
Is there a document describing the change history·between versions?
- Ron
Sadly there is not because we did not develop the firmware in house. Please note that the latest version is always recommended since most changes were made to address limitations or previous bugs. Take care.
Thanks anyway!
How will we know when a new version is released?
Maybe a new section in the Downloads page or a new Forum section?
- Ron
DGSwaner
"When in doubt, use C4" - Jamie Hyneman, Myth Buster
Thanx for the update and the description how-to! I have just succesfully updated Netburner.
BoeBOT with BS2 and PINK module (Netburner) | Latest: BlinkM
Remember, only signals going from the PINK to the Propeller matter.· Signals coming from the Propeller into the PINK module are compatible as they are either way.
There is no problem that can't be solved with a suitable amount of explosives!
EOD Memorial
Both of these files report "invalid or corrupted" when I try to unzip them. I have no problems unzipping other stuff. Does anyone have a valid copy of the PINK firmware? Thanks.
I loaded to my web site for you
http://ronczap.home.insightbb.com/PINK-V1.35.zip
http://ronczap.home.insightbb.com/PINK-SSL-Beta.zip
Do you have ZIP software or just relying on the OS?
Right-click this link and select "Save target as..."
http://ronczap.home.insightbb.com/ParallaxR1p35_APP.s19
Change dropdown "Save as type" to "All files"
Save the file as "ParallaxR1p35_APP.s19"
This was really odd. I tried it on two different machines, both running XP SP3, and they both gave that same error. I just downloaded them with Firefox and then double clicked on the resulting file to unzip. I don't have any other way to do it, like Winzip.
I also run XP Pro SP3 and I tried using Firefox. I was able to Save each zip file and then open them using either WinZip or by right clicking the zip file and selceting "open with" and choosing "Compressed (zipped) Folders" from the menu.
http://www.7-zip.org/
And thanks for the tip for 7-zip. It looks like a good program, though it wasn't able to open that zip file either.
Bummer! :-(
Is there a workaround for this or am I all done? Or how about a fix to autoupdate.exe to recognize the SB70-LC? Thanks.
As of the 15th of December, 2010, all future sales and support of new PINK Modules will be provided by NetBurner. Customers who wish to continue to use the PINK Internet Modules should go to the NetBurner PINK product page for purchases, support and firmware. NetBurner has led the development of the firmware since the introduction of the product and it is easier for everyone for them to drive the product. With Parallax driving this product there is an inherent delay in updates, fixes, etc. since we do not do the firmware deveopment in house. NetBurner will also be able to provide the PINK Module to a much broader base of customers than just Parallax and they may have other options available in the future as product development continues.
The current PINK firmware version is 1.36 and can be downloaded here:
http://www.netburner.com/pink/
I updated my SB70 circuit board version 1.2 to firmware version 1.36. Look OK so far.
Thanks, Marcel
Edit: Never mind. I just found it.
I dusted mine off recently and wasn't sure it would work with my ISP email provider and checked out the netburner site
http://www.netburner.com/support/doc-s-and-downloads (see PINK70 section)
It works fine sending emails using authentication on my timewarner mail server.
Revision history
