Making a zapper?
Microcontrolled
I have recently seen a schematic that shows you how to make a perfect prank zapper out of about 5 parts from a disposible camera. Unfortunatly, I have no disposible camera to salvage the transformer from. Does anyone have some alternate schematics for something like this?
Micro
Check out my new website!!
Use the Propeller icon!!
Follow me on Twitter! Search "Microcontrolled"
Micro
Lots of propeller based products in stock at affordable prices.
Tom Sisk
http://www.siskconsult.com
Just kidding, I want this as a defense for my mini-robot.
This cap will store 11kJ and can deliver a whopping 4800A to your metallic opponent.
Can't wait to see what the EMF from that does to the electronics in your bot!
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should use WD40.
I tried to make one using a computer screen (19 inch Dell) old monitor for the high voltage .. No joke when I got up from the being knocked on my butt my left arm was numb for a few days . It was just to dangerous without schematics to know what I was doing
but MC I would be really interested in circuit to use to charge the cap you posted about?
Cap Charge(:
RC seconds: 63%
2RC: 86%
3RC: 95%
4RC: 98%
5RC: 99%
0.1 ohm resistor gives an RC value of 300 and has a max current draw of 27A
1.8 ohm resistor gives an RC value of 5400 and has a max current draw of 1.5A(mentioned supplies max)
So a 1.8 ohm will take 7.5 hours to charge to 99%
For faster charging you can use a constant current source with a set max voltage. I have not tried this but the LM317 used in the kit mentioned should keep the current at or below 1.5A so you should in theory be able to set the voltage to 2.7V then just hook it up and watch it charge to 100% in 4.5min
It was pretty interesting since instead of winding a coil they used the secondary of 1:1000 transformer.
It seemed really creative.
Never give up,·Never submit to the seemingly invincible enemy.
JS-KB3RBR
For informational purposes only, don't try this at home, not that I'd ever do such a thing. Actually I wouldn't do such a thing for the purpose of shocking soon to be ex friends but those little power supplies also work nicely for powering Nixie tubes.
I know "someone" that would charge high voltage caps (don't know the values) and leave them laying on floor in high traffic areas. " OH, what's this little blue thing on the floor, ZZZZzaP! AAAAH!"
All you need are two electrodes to the heart and one D battery which is enough to stop the heart said my Physics professor in College.
In general it's the voltage that hurts but the current that kills. Low voltage sources are generally considered safe for skin contact because normal skin resistance will not draw enough current from them to do damage. This is not the case if you open the body up and stick the electrodes directly to the heart muscle though, obviously.
The reason the flash power supply is fairly safe is that no matter how low your skin resistance is, it can't push enough current to kill a healthy person; if the resistance is low enough to draw that much current, the voltage will fall instead. The reason it's dangerous to leave the capacitor on is that it will push enough current to hurt you.
Its cause the current is local . its 1CM from pin to pin .
as for a zapper for a robot.
2kJ
nix the zapper . use a coil gun LOLs
( that cap bank is for a 2kJ gun I made .
for MAD ( mutability assured destruction ) Venom would stop any robot (or grage door opener )
