I need same explaining at the SEROUT line!
Hello Forum
I can not understand the - Tx\Rdy - at the SEROUT line, how the SEROUT
commands·could be used for the same·Tx-input, and Rdy-output Pins!?
It's only a little part of the code, the hold code·can be download·here:
http://forums.parallax.com/attachment.php?attachmentid=69525
' Connections:
' BS2······················· SpeakJet IC *
' P15
> pin 10 = Serial TTL
' P14 <
· pin 15 = Serial Flow Control
' Vss·
Gnd
[noparse][[/noparse] I/O Definitions ]
Tx··· PIN·· 15························ ' serial out to SpeakJet
Rdy· PIN·· 14························ ' Ready in from SpeakJet
SEROUT Tx\Rdy, Baud, [noparse][[/noparse]Volume, idx]···· ' set volume level
·The device is a SpeakJet IC. which has a Serial TTL at pin 10 and a Serial Flow Control at pin 15.
·The program is a demo code from Parallax for SpeakJet board.
Thank you
' Connections:
' P15
> pin 10 = Serial TTL
' P14 <
' Vss·
Gnd
Thank you
Tom Sisk
http://www.siskconsult.com
