hOW TO INCREASE THE BASIC STAMP RAM — Parallax Forums
boblai2010boblai2010 Posts: 18
edited 2010-04-20 16:32 in BASIC Stamp
    edited 2010-04-20 14:48
    You can't.
    That said, if you describe what you're trying to do, maybe one of us can make some suggestions since it is possible to attach external memory to a Stamp. It just doesn't work as more RAM as far as the program is concerned. You can't have variables there for example.
  • boblai2010boblai2010 Posts: 18
    edited 2010-04-20 15:12
    can i use two basic stamp to increase the memory i want to enter one code to two basic stamp
    edited 2010-04-20 15:30
    A BS2E had 8 times the EEPROM of a BS2, although it is broken up into eight slots of 2K each.
    edited 2010-04-20 15:33
    OUR school only provide us for the BS2
    edited 2010-04-20 15:38
    You had mentioned using two BS2s, one BS2E is much cheaper than two BS2s.
    Might this indicate some minor lack of efficiency in our educational system, or is an endictment of government bureaucracy as a whole? [noparse]:)[/noparse]
    OR SOMEBODY can help me decrease this program memory
    MY basic stamp still have 4 world 2 byte to use our sensor is sht11 and i want to measure the temperature only
    MODE4:
    ShtData PIN 1 ' bi-directional data
    Clock PIN 0
    ShtTemp CON %00011 ' read temperature
    ShtHumi CON %00101 ' read humidity
    ShtStatW CON %00110 ' status register write
    ShtStatR CON %00111 ' status register read
    ShtReset CON %11110 ' soft reset
    Ack CON 0
    NoAck CON 1
    No CON 0
    Yes CON 1
    DegSym CON 186 ' degrees symbol for DEBUG
    ioByte VAR Byte ' data from/to SHT11
    ackBit VAR Bit ' ack/nak from/to SHT11
    toDelay VAR Byte ' timeout delay timer
    timeOut VAR Bit ' timeout status
    soT VAR Word ' temp counts from SHT11
    tC VAR Word ' temp - Celcius
    tF VAR Word ' temp - Fahrenheit
    soRH VAR Word ' humidity counts
    rhLin VAR Word ' humidity; linearized
    rhTrue VAR Word ' humidity; compensated
    status VAR Byte
    Initialize:
    GOSUB SHT_Connection_Reset ' reset device connection
    PAUSE 250 ' let DEBUG window open
    Main:
    DO WHILE IN0 <> 0 AND IN1 <> 0 AND IN2 <> 0
    SEROUT 14, 84, [noparse][[/noparse]22, 12] ' Initialize LCD
    PAUSE 5
    SEROUT 14, 84, [noparse][[/noparse]"tC = " ,CLREOL, DEC tC, DegSym, "C", CR,"RhLin=" ,DEC rhLin,"% "]
    GOSUB SHT_Measure_Humidity
    GOSUB SHT_Measure_Temp
    PAUSE 1000
    LOOP
    END
    SHT_Connection_Reset:
    SHIFTOUT ShtData, Clock, LSBFIRST, [noparse][[/noparse]$FFF\9]
    SHT_Start:
    INPUT ShtData ' let pull-up take high
    LOW Clock
    HIGH Clock
    LOW ShtData
    LOW Clock
    HIGH Clock
    INPUT ShtData
    LOW Clock
    RETURN
    SHT_Measure_Temp:
    GOSUB SHT_Start ' alert device
    ioByte = ShtTemp ' temperature command
    GOSUB SHT_Write_Byte ' send command
    GOSUB SHT_Wait ' wait for measurement
    ackBit = Ack ' another read follows
    GOSUB SHT_Read_Byte ' get MSB
    soT.HIGHBYTE = ioByte
    ackBit = NoAck ' last read
    GOSUB SHT_Read_Byte ' get LSB
    soT.LOWBYTE = ioByte
    tC = soT ** $1999 - 400 ' convert to tenths C
    tF = soT ** $2E14 - 400 ' convert to tenths F
    RETURN
    SHT_Measure_Humidity:
    ioByte = ShtHumi ' humidity command
    soRH.HIGHBYTE = ioByte
    soRH.LOWBYTE = ioByte
    rhTrue = (tC - 250) * (soRH ** $34) + rhLin
    RETURN
    SHT_Write_Status:
    ioByte = ShtStatW
    ioByte = status
    RETURN
    SHT_Read_Status:
    ioByte = ShtStatW ' write to status reg cmd
    GOSUB SHT_Read_Byte ' send command
    ackBit = NoAck ' only one byte to read
    GOSUB SHT_Read_Byte
    RETURN
    SHT_Write_Byte:
    SHIFTOUT ShtData, Clock, MSBFIRST, [noparse][[/noparse]ioByte] ' send byte
    SHIFTIN ShtData, Clock, LSBPRE, [noparse][[/noparse]ackBit\1] ' get ack bit
    RETURN
    SHT_Read_Byte:
    SHIFTIN ShtData, Clock, MSBPRE, [noparse][[/noparse]ioByte] ' get byte
    SHIFTOUT ShtData, Clock, LSBFIRST, [noparse][[/noparse]ackBit\1] ' send ack bit
    INPUT ShtData ' release data line
    RETURN
    SHT_Wait:
    INPUT ShtData ' data line is input
    timeOut = No ' assume no timeout
    FOR toDelay = 1 TO 250 ' wait ~1/4 second
    IF (ShtData = 0) THEN EXIT
    PAUSE 1
    NEXT
    IF (toDelay = 250) THEN timeOut = Yes ' loop completed = timeout
    RETURN
    SHT_Soft_Reset:
    GOSUB SHT_Connection_Reset ' reset the connection
    ioByte = ShtReset ' reset command
    ackBit = NoAck ' only one byte to send
    GOSUB SHT_Write_Byte ' send it
    PAUSE 11 ' wait at least 11 ms
    RETURN
    Heater_On:
    status = %00000100 ' heater bit = On
    GOSUB SHT_Write_Status
    RETURN
    Heater_Off:
    status = %00000000 ' heater bit = Off
    RETURN
    edited 2010-04-20 16:10
    Here's a couple links to threads talking about streamlining the SHT11 code to save RAM by recycling variables in formulas.
    http://forums.parallax.com/showthread.php?p=826300
    Look at the last post of this one to see some streamlined code. It will read 4 SHT11 sensors and display the results in the debug screen. By streamlining how the formulas work to eliminate extra variables, RAM space was freed up. See Tracy Allen's comments about reducing the accuracy to gain additional space.
    ftp.parallax.com/forums/default.aspx?f=5&m=398907
    another thread with some info
    Andrew Williams
    WBA Consulting
    WBA-TH1M Sensirion SHT11 Module
    Special Olympics Polar Bear Plunge, Mar 20, 2010
    Thank your very much
