Parallax Servos off MC9s12
I am trying to get my Servos running for my Boe bot, and I am doing something wrong... My directional LCD output refreshes fine, but when I go to pump out my pulse train to the servo, I get about a half a second of turning, then my board is cycling, and I get just a tiny pulse to the servo from reset, rinse and repeat. I have only hard coded one direction just to get it working.
Do I have my period and duty cycle wrong? What is causing my board to cycle?
Here is my code. Sorry if I left out some specifics, ask me and I will give it. My brain is fried right now
void set24MHzClock(void);
void init_PWM(void);
void main(void)
unsigned char VT;
while(1)
set24MHzClock();
LCD_init();
init_PWM();
VT = PORTB & 0x1F;
if(VT & 0x10)
switch(VT)
case 0x17:
writeLine("Right ", 0);
break;
case 0x1B:
writeLine("Left ", 0);
break;
case 0x1E:
writeLine("Forward ", 0);
PWME = 0x03;
PWMPER01 = 43400;
PWMDTY01 = 3400;
break;
case 0x1D:
writeLine("Reverse ", 0);
break;
default:
writeLine("Invalid ", 0);
break;
else
writeLine("Stopped ", 0);
//PWM INIT//
void init_PWM(void)
PWMPOL = 0x01; // High at beginning, low at end (active high).
PWMPRCLK = 0x00; // Prescaler.
PWMCLK = 0x00; // Sets clock A to be ch 1 clock.
PWMCTL = 0x10; // Sets up ch0+1 16bit.
PWME = 0xFF;
- set24MHzClock
- Sets up phase-locked-loop and clock source, etc., for 24 MHz operation
CLKSEL = 0; // Use crystal oscillator for E clock
PLLCTL = 0; // PLL off
SYNR = 2; // PLL X3
REFDV = 0; // ???
PLLCTL = 0x40; // PLL on
while( !( CRGFLG & 8) )
{ } // Wait for lock-up
CLKSEL = 0x80; // Use PLL for system clock
Parallax Engineering
