Boe-Bot servo question
Ok, this is a super noob question I hope. I've successfully centered and tested both the left and right servo motors, and assembled the boe-bot. Unfortunately I may an error when I plugged the Left servo into the P13 slot with the colours of the wires on the input "jack" opposite to what they were supposed to be. So of course, i fiddled with the potentiometer before i finally figured it out and switched and now the servos do not behave properly. Here's what I've tried and what i've noticed.
1) i unhooked the servo and wheel and ran the center servo test program. the serve moves a tiny bit and stops
2) the servo will turn when I run one of the clockwise or counterclockwise turn programs, except it always turns counterclockwise regardless of the duration
I hope that was clear enough, any suggestions as to how I can remedy this problem
Thanks.
Thanks.
When I sat down and though about it logically the answer came to me.
