Faulty Boe-bot Infrared
Hello,
I am new to this forum so I'm not sure if this is where I put this post.· I have a Boe-bot with the Basic Stamp programming.· My problem is with the infrared sensors, they just won't work.· I wired them according to the manuel, and at first they worked, but one day they wouldn't sense anything.· I've discussed it with my robotics teacher, we tried rewiring it, and changing the batteries on the bot.· The sensors were tried on another Boe-bot, and worked perfectly.
I was wondering if it was my wall-following program, but I can't find anything wrong with it.
Any ideas?
Mousepad
Post Edited (MousePadGirl) : 4/21/2010 10:16:48 PM GMT
Any ideas?
Mousepad
It would help for you to provide a copy of the source of your program as an attachment to a message (use the "Post Reply" button and the "Attachment Manager") and some kind of schematic drawing of how you have things connected.
Sorry, I am seriously new to this whole thing. Thanks for the advice!
Mousepad
Also, provide a subject for your thread, something meaningful please. Since you started this thread, you can change it. Use the pencil icon in the upper righthand corner of your first message.
One thing I forgot to mention about working with the wiring, was the infrared detectors were hot to the touch, after just a few minutes of the bot being on.· I'm not sure if this information was relevant, but it was kind of odd, and might have something to do with the issue.
' {$STAMP BS2}
' {$PBASIC 2.5}
irdetectright· VAR Bit
pulseleft····· VAR Word
pulseright···· VAR Word
LeftPR···· CON· 130
Leftbright CON· 79
FREQOUT 8, 1, 38500
FREQOUT 4, 2000, 3000
DO
·FREQOUT 2, 1, 38500
·irdetectright = IN0
·IF (irdetectright = 0) THEN
·pulseleft = 720
·pulseright = 650
·ELSEIF (IN6 = 1)
·ELSE
· pulseleft = 850
· pulseright = 720
·ENDIF
·PULSOUT 13, pulseright
·PULSOUT 12, pulseleft
·PAUSE 15
LOOP
Thanks again!
Mousepad
2) The IR detector should not get hot. Make sure it's connected properly. It may be connected backwards. If so, it might be damaged. If you have the 220 Ohm resistor in the circuit as shown, the resistor will prevent the Stamp from being damaged as well.
3) What are pins 4 and 8 used for? You really need some comments in your program to explain what you're trying to do.
4) Next time, please use the Attachment Manager rather than cut and paste. The forum software normally strips out leading spaces and some other formatting. Posting the code as an attachment avoids this. At least use the [noparse][[/noparse] code ] and [noparse][[/noparse] /code ] brackets (without the extra spaces). This will preserve some of the formatting.
