Serial communications to propeller chip
hey guys, I really need help with this. I am working in a school project. I need to get serial data from a UART to a propeller so that I can get the data I need from that serial string of data.
I would get about 48 bits of data out (preamble, id, data, end) and I need to make the propeller do a task depending on what data I get. However, I am not sure how I can interace a propeller chip with a uart to get that serial information out and do something with it.
Thank you and I would really appreciate your help.
For software, look at the FullDuplexSerial object from the Propeller Object Exchange. This also comes along with the Propeller Tool when you install it. It provides a full duplex serial channel up to about 230KBaud when you're using the Propeller's normal 80MHz system clock. If you browse through the Object Exchange, you'll find several other serial objects with different features.
The FullDuplexSerial object will provide you with a "get a character" and an "is there a character" routine. You'll have to do all the programming to figure out what to do with the characters. It shouldn't be hard.
What should we use for the Propeller? +3? Or +5? Or are both of them correct?
I ordered a Propeller Professional Development Board and I want my Propeller to talk to my Javelin.
The javelin uses TTL level signals (0 and 5V). So can I just connect it directly to the Propeller?
Also, will the Propeller's frequenze have impact on the communication? If I use it at 5Mhz instead of 80Mhz, or if I use it at 100Mhz, will the FullDuplexSerial object or others ajust? Or it will not work anymore?
JM
Re baud rates, these are all standardised, so you can start slow and work up. The clock frequency of the micro does not matter. 1200 baud is a safe place to start, especially as bytes are slow enough you can put a led on the port and watch each byte go through. Then you can increase the speed. If you have cables more than a few metres long you might start getting problems faster than 38400.
Baud rates will be one of:
110, 300,600,1200,2400,4800,9600,19200, 38400, 57600, 115200 and even faster if you like.
www.smarthome.viviti.com/propeller
