Bridge rectifier for DC voltage when using motor as a generator. Quick question
Hey, I have a simple question:
I am spinning the shaft of a DC motor to produce electricity (generator). Depending on the direction of shaft spin, the motor produces positive voltage in one wire Or the other. I want to apply this voltage to my basic stamp without having to worry about which direction the motor shaft is spinning...
Thus, can I use a bridge rectifier for this situation? I know a bridge rectifier is normally used to convert AC voltage into DC. But can it also be used to make sure I'm not flipping the voltage to my basic stamp from my DC generator if I turn it the wrong way?
As for ratings on the bridge rectifier, do I pick one that has voltage and current ratings that I know I will never exceed?
I'm pretty sure I know the answers to these questions, but just wanted a second opinion.
Blake
Blake
"The man who smiles when things go wrong has thought of someone to blame it on."
-Lucky[size=-1][/size]
Blake
