What must I do to get 54 characters per line with TV_Text_Half_Height from Obex? — Parallax Forums
Christof Eb.Christof Eb. Posts: 1,465
edited 2010-04-17 09:46 in Propeller 1
in the file it is stated, that 54chars per line would be possible in pal mode.
I use the pin configuration of the demo board and I have 5MHz*16.
Thanks alot for some directions!
Christof
  • ColeyColey Posts: 1,130
    edited 2010-04-16 19:02
    Hi Christof,
    Have you changed the _xinfreq in the top object?
    Baggers has used a 6MHz crystal so that will need changing for demoboard compatability.
    To get 54 characters on Demoboard change
    text.start(24,0,0,40,15)
    to
    text.start(12,0,0,54,15)
    and in TV_Text_Half_Height object change hx settting in tv_params DAT block to 6
    tv_params               long    0               'status
                            long    1               'enable
                            long    0               'pins
                            long    %10010          'mode
                            long    0               'screen
                            long    0               'colors
                            long    40              'hc
                            long    30              'vc
                            long    6               'hx
                            long    1               'vx
                            long    0               'ho
                            long    0               'vo
                            long    0               'broadcast
                            long    0               'auralcog
    I hope that helps....
    Coley
    PropGFX - The home of the Hybrid Development System and PropGFX Lite
  • Christof Eb.Christof Eb. Posts: 1,465
    edited 2010-04-17 06:36
    Thank you, Coley.
    I have tried this - actually I had tried these things before, but there must be an additional trick. I can display 40*30 using
    text.start(12,1,1,40,30)
    I would suppose, that some kind of bitout frequency has to be changed, because there are more pixels to be shifted out.
    I still have:
    fntsc = 3_579_545 'NTSC color frequency
    lntsc = 3640 'NTSC color cycles per line * 16
    sntsc = 624 'NTSC color cycles per sync * 16
    fpal = 4_433_618 'PAL color frequency
    lpal = 4540 'PAL color cycles per line * 16
    spal = 848 'PAL color cycles per sync * 16
    paramcount = 14
    colortable = $180 'start of colortable inside cog
    despite of 5MHz, I wonder if this is correct for 54Chars.
    Christof
    Post Edited (Christof Eb.) : 4/17/2010 6:45:12 AM GMT
  • BaggersBaggers Posts: 3,019
    Christof Eb. I unfortunately don't have any demo or proto boards, as I gave them away at the Maker Faire, so I can't test it at 5Mhz.
    You shouldn't need to do more than the HX value, and the values in the text.start
    I tried to make it as easy to set up as possible.
    I'll try and get hold of another demo/proto board and get it working with 54 Chars, although 864 pixels is a LOT of pixels to get on the screen in NTSC and with a 5Mhz crystal, especially considering it's mixing two scanlines of pixels together.
    Cheers,
    Baggers.
    http://www.propgfx.co.uk/forum/·home of the PropGFX Lite
