using variables with floatmath ?
Please help, I think the problem described below has exceeded my small skills with the propeller.
I am trying to scale the output of an ADC0831 to display 0.0· to 5.0 volts depending on its Output of· from 0 to 255. I am dividing 5 by 255 and using the result of 0.0195 as
A multiplier to determine the voltage
Example:··· ADC puts out a value of 127, to convert this to a voltage, I multiply
················ ,0195 by 127 which equals a voltage of· 2.47
After spending a lot of time and trying most of the math objects ·to program this, I discovered that you cannot use interger variables in the float math formula. You must use· values that contain a decimal Point and one integer.
Example:· you cannot use 127, you must use 127.0 ·
Is there an object or formula to convert integer variables to variables containing
A decimal point and the option to add a 0 after the decimal?· Or am I not seeing the forest
for the trees and there is a simple solution I have overlooked?
Example:
Convert·· the variable 127 to 127.0··
The program below is what I have been working on. If you run it, it will not display the
Correct result. If you change the firstnumber variable to 127.0 it will work correctly
Many thanks for any solutions, or suggestions..
CON
· _clkmode = xtal1 + pll16x
· _xinfreq = 5_000_000
· adcmultiplier =0.0196
OBJ
· ser···· : "fullduplexserial"
· f······ : "FloatMath"
· fp····· : "FloatString"
VAR
· long firstnumber, secondnumber
PUB start
· ser.start(31, 30, 0, 9600)····
· firstnumber :=127· 'value from ADC0831 (0 to 255)
·· repeat
····· secondnumber:=f.fmul(firstnumber, adcmultiplier)· '· multiplies two decimal numbers···
····· secondnumber:=(fp.FloatToString(secondnumber)) 'converts float number to string·····
····· ser.str(string("· secondnumber·· float to string result = "))·
····· ser.str(secondnumber)··· 'display converted float to string value
····· ser.tx(13)'carriage return
····· waitcnt (40_000_000 + cnt)
Example:
CON
OBJ
VAR
PUB start
·· repeat
so just wrap your integer in fp.FFloat()
firstnumber :=(f.ffloat(firstnumber)) the program works properly.
CON
OBJ
ser : "fullduplexserial"
f : "FloatMath"
fp : "FloatString"
VAR
PUB start
firstnumber :=115 'value from ADC0831 (0 to 255)
repeat
secondnumber:=f.fmul(firstnumber, adcmultiplier) ' multiplies two decimal numbers
ser.str(string(" secondnumber float to string result = "))
ser.str(secondnumber) 'display converted float to string value
waitcnt (40_000_000 + cnt). O
