poor man's photobeam break sensor
I'm looking for a way to trigger someone crossing a path without using a PIR sensor since it has to cover a 30-40 foot range.· I've found units that do that, but they are somewhat pricy.
I was thinking about having a 40Khz IR emitter on one end and the sharp receiver on the other.· Does anyone see a flaw in this approach?
If I could do a reflector it owuld be better since I could keep all the electronics on one side, but I wasn't sure if the 40KHz emitter circuit I have would have enough power to reach there and back, or if reflectors actually work on IR.
Thoughts?
Thanks.
Jeff
End dependance on foreign oil.· www.pickensplan.com
Thoughts?
Thanks.
Jeff
I figure I could get an IR camera to see if the reflector shines back. I built an IR emitter from a kit once (TV B Gone) and we were able to test the emitter by shining it on a webcam which showed on the screen as a regular light, so I figure I could do the same to get it pointed right.
Of course rain could be a concern, but I can handle a few false positives.
I will also need to develop a simple circuit that would go high when the IR signal is broken for half a second. I figure a simple RC circuit and a comparitor.
Not sure what u are saying just had a quick reading so came up with this idea.
I am just a student. I might be wrong.
But I don't know if the natural IR in the environment from the sun during the day would throw it off.
Post Edited (jeffjohnvol) : 4/14/2010 12:54:17 PM GMT
Actually, that's a pretty good idea. A laser diode, tiny mirror and a photresistor (or photodiode)..... $10 Cool!
"puff"...... Smile, there went another one.
