Error:148 - help with program to drive motors based on color sensed by camera
The students are using a camera that senses colors.· They
have this working properly.· They also have the program
driving a motor.
The problem:· They can not get the motors to drive based on
the color sensed.
This is the error:· Error:148:Expected a Label
Program line is:·
Line IF (pRed<85) AND (pGREEN<42) AND· (bBLUE<26) THEN...
driving a motor.
the color sensed.
Program line is:·
If you post the program we can offer some suggestions, but the label missing is a subroutine, variable, or something similar that is used in the program that is not being declared somewhere. Can you post the entire program using the Attachment Manager?
Respectfully,
Joshua Donelson
www.parallax.com
- Stephen
' {$PBASIC 2.0}
Out CON 7
S3 CON 0
S2 CON 1
LED CON 5
pRED CON 15
pGREEN CON 12
pBLUE CON 9
RED VAR Word
GREEN VAR Word
BLUE VAR Word
Counter VAR Word
START:
HIGH LED
DO
GOSUB Register
GOSUB Seperator_move
LOOP
Register:
GOSUB Color
DEBUG "R", DEC3 RED
DEBUG " G", DEC3 GREEN
DEBUG " B", DEC3 BLUE
DEBUG CR
RETURN
Color:
LOW S2
LOW S3
COUNT Out, pRED, RED
HIGH S3
COUNT Out, pBLUE, BLUE
HIGH S2
COUNT Out, pGreen, GREEN
RETURN
Seperator_move:
IF (pRed < 85) AND (pGREEN < 42) AND (pBLUE < 26) THEN SHIFT:
FOR Counter = 1 TO 24
PULSOUT 13, 750
GOSUB Semi_seperator
PAUSE 20
NEXT
PULSOUT 13, 850
PAUSE 20
NEXT
ELSEIF (pRED < 55) AND (pGREEN < 76) AND (pBLUE < 43) THEN SHIFT:
FOR Counter = 1 TO 64
PULSOUT 13, 750
PAUSE 20
NEXT
PULSOUT 13, 850
PAUSE 20
NEXT
ELSEIF (pRED < 31) AND (pGreen < 37) AND (pBLUE < 43)THEN SHIFT:
FOR Counter = 1 TO 104
PULSOUT 13, 750
PAUSE 20
NEXT
FOR counter = 1 TO 104
PULSOUT 13, 850
PAUSE 20
NEXT
ELSE SHIFT:
FOR Counter = 1 TO 144
PULSOUT 13, 750
NEXT
FOR counter = 1 TO 144
PULSOUT 13, 850
PAUSE 20
NEXT
ENDIF
PAUSE 20
RETURN
Semi_seperator:
PULSOUT 12, 750
PAUSE 20
NEXT
RETURN
Program attached.
Thanks for helping.
Are you using the TAOS (TCS3200-DB Color Sensor) color sensor module? Or what camera are you using?
I see the program is using ELSEIF, and that is a PBASIC 2.5 command. What you would want to do is use the 2.5 PBASIC directive to select the latest command set in PBASIC and try the run the program again.
Respectfully,
Joshua Donelson
www.parallax.com
·I dont think you are running into a barrier but a formatting related issue. I see that you are using a SHIFT routine a number of times. Since each one is doing something different you would want to give unique names like you are using the Simi_seperator routine, so something like SHIFT_1, SHIFT_2, and so on.
·You can try something like the following; breaking the program up into easier to manage parts. Each IF...THEN statement has a specific place to jump to if the statement is true.
Seperator_move:
·· IF (pRed < 85) AND (pGREEN < 42) AND (pBLUE < 26) THEN SHIFT_1
·· ELSEIF (pRED < 55) AND (pGREEN < 76) AND (pBLUE < 43) THEN SHIFT_2
·· *other IF...THEN statements continued here...
'· Sub Routines Names
SHIFT_1:
··· FOR Counter = 1 TO 24
······ PULSOUT 13, 750
······ GOSUB Semi_seperator
······ PAUSE 20
······ NEXT
····· PULSOUT 13, 850
····· PAUSE 20
····· NEXT
RETURN
SHIFT_2:
···· FOR Counter = 1 TO 64
······· PULSOUT 13, 750
······· GOSUB Semi_seperator
······· PAUSE 20
······· NEXT
····· FOR Counter = 1 TO 64
······· PULSOUT 13, 850
······· PAUSE 20
······· NEXT
RETURN
** other Sub routines continued here
Hope this helps,
Respectfully,
Joshua Donelson
www.parallax.com
Respectfully,
Joshua Donelson
www.parallax.com
·There is a specific format that a IF...THEN statement must follow to properly compile. An IF...THEN statement can be completed on one line, which does not need an ENDIF, or multiple lines; the common practice when using ELSE and ELSEIF, followed by an ENDIF.
·I would suggest reviewing the IF...THEN statement in the BASIC Stamp Syntax & Reference Manual as there are some nice examples of using a ELSEIF with an IF...THEN command with some code snippets. Here is a link for your convenience.
BASIC Stamp Syntax & Reference Manual:
http://www.parallax.com/Portals/0/Downloads/docs/prod/stamps/web-BSM-v2.2.pdf
Respectfully,
Joshua Donelson
www.parallax.com
