Com Port problem Vista — Parallax Forums
Don JDon J Posts: 12
edited 2010-04-13 14:55 in BASIC Stamp
I am trying to communicate with a BS2 using Windows Vista and I keep getting stamp not found.
Anyone have any insight ?
I have a Dell Latitude with an actual serial port.
I've checked the baud rate etc..etc.. and still no luck.
Just got back into stamps and I used Windows XP prior to this without any problems.
Thanks Don J
    edited 2010-04-13 07:08
    1) Stamp known good? Plugged in properly to the board?
    2) Does Vista support the serial port? You may need a virtual serial port; a USB-serial adapter. Try an XP computer w/serial port and make sure your cable works. Null modem cables don't. On some computers, you don't need a cable, you can plug the Stamp Carrier or BoE directly onto the computer's serial port. BTW, I'm using Vista with a USB serial adapter, no problems.
    3) A low battery is often the culprit.
  • hippalatorhippalator Posts: 12
    edited 2010-04-13 11:44
    Just hooked up the serial BOE to my windows 7 and worked just fine.
    I know window7 is not Vista but from the IT department here at work Windows 7 is Vista revamped.
  • Don JDon J Posts: 12
    edited 2010-04-13 14:04
    I'm going to try a known working computer running XP.
    I use a USB to serial converter called an Edgeport.
    This had worked well for me a couple years ago.
    Also this is an OEM BS2 that I just put together.
    Don J
    edited 2010-04-13 14:30
    Ok, no luck using the Edgeport converter with a known working computer.
    This was a known working configuration a few years ago.
    When I do a control I the port status shows loopback = yes on the port that the stamp is connected to.
    When I try to upload the program, I still get stamp not found.
    My first thoughts are that the stamp was not put together properly, but I have soldered these
    before without a problem and there just isn't a whole lot of rocket science to it.
    Continuing testing...
    Don J
    Ok, Progress !!!
    I had a Rev A2 board laying around.
    The A2 Compiler and Pic were damaged in an earlier incident.
    Took the Pic and Compiler out of my new Rev B board and plugged it into my A2 board.
    The BS2 is now working properly on my Vista machine.
    So, now..trouble shoot the Rev B board and get that operational.
    Don J
