LISY300 Gyroscope Module/forgot one of the applications
I have tried to use three of the above gyros for x,y,z data and have a problem that I would like to post
to the forums and see if anybody has an idea.
Whether I use separate cogs or one cog, I can only get two gyros to work at a time. Has anybody
had this problem?
I have attached my programming and would like a suggestion.
I have swapped gyros, gyro data/cs/clk pins and used separate power supplies and can only get
two to work at a time. I have also added an accelerometer to see if I would loose a second gyro and
only have one left and did not have any changes. No matter what I can only get two out of three gyros
to work.
Thanks.
had this problem?
to work.
Thanks.
Anyway, you are using common variables for the gyro pin numbers. Now maybe while the cog is loading up and running your top level spin is changing the pin numbers on it, causing a clash of pin numbering. I would seperate these calls to ensure this is not possible first.
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)·
· Prop OS: SphinxOS·, PropDos , PropCmd··· Search the Propeller forums·(uses advanced Google search)
My cruising website is: ·www.bluemagic.biz·· MultiBlade Props: www.cluso.bluemagic.biz
