LISY300 Gyroscope Module
I have tried to use three of the above gyros for x,y,z data and have a problem that I would like to post
to the forums and see if anybody has an idea.
Whether I use separate cogs or one cog, I can only get two gyros to work at a time. Has anybody
had this problem?
I have attached my programming and would like a suggestion.
I have swapped gyros, gyro data/cs/clk pins and used separate power supplies and can only get
two to work at a time. I have also added an accelerometer to see if I would loose a second gyro and
only have one left and did not have any changes. No matter what I can only get two out of three gyros
to work.
Thanks.
had this problem?
to work.
Thanks.
