Stepper motor control?
Can I use some power transistors to control a stepper motor instead of using a darlington array? I don't have the uln2003, and I have a bunch of power transistors... I was thinking of having an I/O of the BS2 forward-biasing the transistors, with the collector connected to 6 volts and the emitter connected to the stepper motor pin. Would that work?
MCU Projects·- my new site where I will be posting all projects, code, etc.
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
SD Card Adapter·- Add extra memory to your next Propeller project with ease!
The Darlington Array is a set of 8 transistors; so yes, you could use a bank of transistors to accomplish the same task.
Respectfully,
Joshua Donelson
www.parallax.com
Have fun
