pwm response
Hi Guys,
I was wondering do any of you guys know how fast I can pump a sine wave out of the prop.· Im building a system that needs a frequency response on the order of 1 khz.· Im hoping to use the pwm and smoothing filters in order to do this. A penny for your thoughts.
yes 1kHz sine wave can be done.
But the methods to do it depend for example from the needed resolution/quality of the sinwave.
I personally would tend to use PropBasic. In my "ProprSound" Project there is a sine generator task hidden, that I used for tests.
http://forums.parallax.com/showthread.php?p=893799
I·used it with 1kHz for example. Only a simple RC- filter is used.
You could use a resistor ladder as·DAC too. Then you need not much software.
Good luck,
Christof
I really don't want to switch gears and learn new software, but I think your right.· I have been struggling through the counter docs.· I'll see how it goes.
Greg
Check out Drones excellent Sinewave code here:
http://forums.parallax.com/forums/default.aspx?f=25&m=442433
I too need sinewaves, and others have been helping me here:
http://forums.parallax.com/forums/default.aspx?f=25&m=441610
Fred
________________________________
Work:www.vhf.ca··Play:www.Costalegre.ca
