How to increase your Wifi signal?!
Will this really work?· I haven't tried this but I have a 25 foot ethernet wire and I'm going to try it.
I'm wondering if it works, will there be any applications for any projects here?
But I've done some amazing stuff with a little foil.. It can be used for directing signals longer distances.
(Pringles cans are fun for this too..)
Fun video, but a spoof..
OBC
Are you Propeller Powered? PropellerPowered.com
Visit the: PROPELLERPOWERED SIG forum kindly hosted by Savage Circuits.
BTW, I just realized that, by a really odd juxtaposition, my post in this thread, which may appear to apply the "Lirpa Principle" to sound, could also be taken as a spoof. It's not. It really works!
Post Edited (Phil Pilgrim (PhiPi)) : 4/11/2010 8:17:25 PM GMT
Pair's satirical videos have 'Infinite Solutions' for comedy
The ARRL has a variety of booklets on antennas, transmission lines, etc. that you can probably find in any good library. You should be able to find other material in the Wikipedia. Start with Antenna and go from there.
There are several cheap ways to get great wifi range.
Maximum range requires a USB wifi dongle connected to
a feedpoint antenna such as a simple biquad. Mount the biquad
at the feed point of an old direct tv or dish network dish and
aim at the horizon. These dishes look like they are aimed toward the
ground when they are pointed at the horizon...google for
details on how to mount and aim these things. I recommend a half watt
USB dongle like the great one made by alfa...you can find these on
ebay. You can get about 26db gain with a small dish system like this.
You can go over 30db if you do the same thing with an old tvro
dish of 8 to 16ft diameter....the world wifi record is held by a system
like this using a 12ft tvro dish. (people will give you those old giant dish
antennas just to be rid of them) You need a wifi dongle with an rpsma jack
to feed the biquad.
The reason a USB wifi adapter is better than an internal network card
is that feedline cable at this frequency is very lossy! Better to have the
2ghz receiver and transmitter right at the feedpoint and use a good
quality long USB cable to connect to the PC....large conductors and
good shielding.
A good boost can be had by mounting a cheap $5-10 USB wifi dongle in front
of something like a wok pan. Just google for directions. An old
tin can will also give a good boost if you mount the USB dongle in just the right spot.
There are many websites with directions for all of this, just google.
shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=alfa+wifi&_sacat=See-All-Categories
Post Edited (HollyMinkowski) : 4/12/2010 10:01:55 PM GMT
Signature space for rent!
Send $1 to CannibalRobotics.com.
