Propeller Proto Boards and using upper 32KB of AT256 EEPROM for storing data.
So I was looking at at my Propeller Proto Board the other day and I noticed that it has an AT256 EEPROM (64KB) like it says in it products description. Interestingly, the schematic shows a 128Kbit part. Anyway, my question is can the upper 32KB ( > $8000) be used for storing data? I wonder why there is not more discussion on doing such.
James Ronald
My Robots
Post Edited (JamesRonald) : 4/11/2010 2:26:43 AM GMT
James Ronald
My Robots
Leon Heller
Amateur radio callsign: G1HSM
You can use all of the 32K above the original 32K. There has been much discussion, but searches are not working in the forum right now. I'll see if I can track down some threads.
Jim
Good catch on the schematic. Don't know if it's a documentation error, or they had another part in mind.
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 _stack = 50 i2cSCL = 28 ' i2cSDA = 29 EEPROMAddr = %10101000 ' EEPROM data base address - i.e 32K (assumes a 64kb eeprom installed!!) EEPROM_Base = $8000 ' debug - USE onboard pins pcDebugRX = 31 pcDebugTX = 30 ' serial baud rates pcDebugBaud = 115200 VAR long i2cAddress, i2cSlaveCounter OBJ i2cObject : "basic_i2c_driver" debug : "Debug_PC" pub Start ' start the PC debug object debug.startx(pcDebugRX,pcDebugTX,pcDebugBaud) ' setup i2cobject i2cObject.Initialize(i2cSCL) ' pause 5 seconds repeat 10 debug.putc(".") waitcnt((clkfreq/2)+cnt) debug.putc(13) ' i2c state debug.strln(string("Logger program (v1.0)")) ' demo the EEPROM if i2cObject.devicePresent(i2cSCL,eepromAddr) == true debug.strln(string("EEPROM Present")) EEPROM_Demo else debug.strln(string("EEPROM Missing")) waitcnt(clkfreq*3+cnt) PRI EEPROM_Demo | eepromData, eepromLocation, ackbit ' demo the i2c Serial EEPROM (Microchip's 24LC512 (64kb)) debug.strln(string("EEPROM DEMO")) ' ***** EEPROM read/Write example ***** eepromLocation := EEPROM_Base eepromData := 0 repeat 10 ' write long eepromData += 100 i2cObject.WriteLong(i2cSCL, EEPROMAddr, eepromLocation, eepromData) ' read long eepromData :=0 eepromData := i2cObject.ReadLong(i2cSCL, EEPROMAddr, eepromLocation) ' debug debug.str(string("Read Location=")) debug.decx(eepromLocation,5) debug.str(string(", data=")) debug.decx(eepromData,5) debug.putc(13) ' next eepromLocation +=4 ' slowit waitcnt(clkfreq/2 + cnt) ' done debug.strln(string("EEPROM demo done."))It uses other code from the Obex.
Leon Heller
Post Edited (Leon) : 4/10/2010 8:47:56 PM GMT
I have been watching the propeller and robotics forums for a couple years now and do not remember this topic coming up.
Thanks for the help.
James Ronald
My Robots
Leon Heller
Here is another in the OBEX that stores and retrieves data from eeprom. I am unsure if this just accesses 32KB but it could no doubt be modified. http://obex.parallax.com/objects/493/
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)·
· Prop OS: SphinxOS·, PropDos , PropCmd··· Search the Propeller forums·(uses advanced Google search)
My cruising website is: ·www.bluemagic.biz·· MultiBlade Props: www.cluso.bluemagic.biz
I tried above code.
But not operate. (all data are FFFFF)
I checked ProtoBoard(AT24C512)
I modify to EEPROMAddr := %10100000).
I comment out " if i2cObject.devicePresent(i2cSCL,eepromAddr) == true", because there is no method "devicePresent" in object"basic_i2c_driver"
Why cannot data read?
Ben
I modified below.
It fine works.
eepromLocation := 0 eepromData := 0 repeat 10 ' write long eepromData += 100 'i2cObject.WriteLong(i2cSCL, EEPROMAddr, eepromLocation, eepromData) BS2.Write_HighMem(eepromLocation, eepromData, 4) ' read long eepromData := 0 'eepromData := i2cObject.ReadLong(i2cSCL, EEPROMAddr, eepromLocation) eepromData := BS2.Read_HighMem(eepromLocation, 4)Why doesn't i2cObject.WriteLong/i2cObject.ReadLong work?
I don't understand reason although reading basic_i2c_driver.
