Simple LCD problem (I Hope)
Carol Hazlett
I am building a homegrown Bot using a BOE Rev C, to go with my older BoeBot which uses the BOE Rev B.· I have two of the little AppMod LCD's· but
while it works fine on the Rev C board it will not work at all on the Rev B board.· I did a lot of searching through the Parallax literature and searched this forum also but have not found a specific reference to this.· Thanks ahead for any help.
The second childhood is the best because now·you have money for toys.
Are you saying if you move a working LCD AppMod from the RevC Board to the Rev B board it stops working even with the same code and same BASIC Stamp Module?
Parallax Engineering
Is there a way to make·the appmod·work with the older stamp?
