Propeller power problem
Hi, I was wondering if you could directly connect two 1.5 volts AA batteries to the propeller without over heating it. If it does overheat would a 10k resistor help if it intersects the battery and the propeller. Thank you a lot!
Two 1.5V batteries in series, even if they are fresh and have slightly higher terminal voltage will never be a Problem with the Prop.
*Peter*
