Will 10 Mhz crystal work with propeller?
Hi, will this crystall work with the propeller? http://www.goldmine-elec-products.com/prodinfo.asp?number=G13554·and if it will than won't the propeller operate twice as fast a with a 5Mhz crystal?
The SpinStamp and the Hydra both use 10MHz crystals.
and that is the same as a 5mhz xtal at 16x = 80mhz
You can run a 6.250xtal and get 6.25 x 16 = 100mhz
these xtals are 1.25 each.
Or use a 6.00mhz xtal and get 96mhz
I ordered some new xtals a few days ago...they have not arrived yet
but they cost .23 each. I got some 6.000 and even a few 6.400
to see how they will work with the prop. 6.400 may be asking too
much but the prop just might manage to run at 16x 6.400
www.taydaelectronics.com/servlet/the-Crystals/Categories
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)·
· Prop OS: SphinxOS·, PropDos , PropCmd··· Search the Propeller forums·(uses advanced Google search)
My cruising website is: ·www.bluemagic.biz·· MultiBlade Props: www.cluso.bluemagic.biz
search.digikey.com/scripts/DkSearch/dksus.dll?WT.z_header=search_go&lang=en&site=us&keywords=300-8426-ND&x=0&y=0
The reason I use 10MHz is because they are more readily available then the 5MHz values. Digikey seem to have fractional 6MHz values in stock as well. One off price is 63c but if you buy 100 (why wouldn't you) the price is only 36cents each.
An advantage that the through-hole crystal has over the HC49 style is that the crystal takes up not only less room on the pcb but also less in copper real-estate. The HC49 has contacts that are huge and awkward to place close to the Prop chip yet the cylinder style just needs 2 little holes that you can place right next to the Prop and that doesn't get in the way of other pins. Compare two similar pcbs that I did and you can see the HC49 had to go on the other side of the pcb because it could not be placed close to the Prop without blocking all the pin connections. I didn't place the cylinder style crystal as close to the Prop in this pcb because it was a very crowded pcb.
*Peter*
Those tiny round xtals look pretty good.
.37 each if you buy 100 of them....not a bad price either.
I think I will try a few of them.
Hi Peter,
Should PWM be working with the latest Forth and Extend? I am using:
MODULES LOADED:
1A81: EXTEND.fth Tachyon Forth Propeller hardware debugger and explorer - 150902-0100
VER: Propeller .:.:--TACHYON--:.:. Forth V27150902.0100
FREQ: 80MHZ (PLLEN OSCEN XTAL1 PLL16X)
NAMES: $5491...7163 for 7,378 bytes (+125)
CODE: $0924...4482 for 15,198 bytes (+1,309)
CALLS: 315 vectors free
RAM: 4,111 bytes free
BUILD: FIRMWARE BUILD DATE 654545:466585
BOOTS: 1
BOOT: EXTEND.boot
POLL:
I then load this code:
TACHYON [~
: motor.FTH ." Motor driver for Jimmy the mouse bot " ;
Motor driver for Jimmy the mouse bot.
Using L298 compact motor driver H bridge - Solarbotics
P26 enable right motor
P27 enable left motor
P22 L1
P23 L2
P24 L3
P25 L4
start with initpwm to initialize the PWM
DECIMAL
\ 1 - allocate memory for a table
256 LONGS pwms \ allocate a 256 longs table for the PWM samples
: initpwm
\ 2 - specify the outputs and the address of the table then the freq and start the PWM cog
\ Start up PWM using from P0..7, P16..P23 for 16 channels
\ PWM.START ( iomask table freq -- )
\ %00000110_00000000_11111111_11111111
%00001100_00000000_00000000_00000000 pwms 6000 PWM.START
: driveahead
\ 3 - set the duty cycle for individual pins or groups of pins
100 % 26 SETPWM
100 % 27 SETPWM
\ motors drive ahead
\ left motor
#P22 LOW
#P23 HIGH
\ right motor
#P24 LOW
#P25 HIGH
: drivebackw
\ drive backwards
100 % 26 SETPWM
100 % 27 SETPWM
\ left motor
#P22 HIGH
#P23 LOW
\ right motor
#P24 HIGH
#P25 LOW
: driveleft
100 % 26 SETPWM
90 % 27 SETPWM
\ left motor
#P22 LOW
#P23 HIGH
\ right motor
#P24 LOW
#P25 HIGH
: driveright
90 % 26 SETPWM
100 % 27 SETPWM
\ left motor
#P22 LOW
#P23 HIGH
\ right motor
#P24 LOW
#P25 HIGH
\ tank style on place turning
: turnright
50 % 26 SETPWM
50 % 27 SETPWM
\ left motor
#P22 LOW
#P23 HIGH
\ right motor
#P24 HIGH
#P25 LOW
: turnleft
50 % 26 SETPWM
50 % 27 SETPWM
\ left motor
#P22 HIGH
#P23 LOW
\ right motor
#P24 LOW
#P25 HIGH
: drivestop
\ switch motors off
1 % 26 SETPWM
1 % 27 SETPWM
\ left motor
#P22 LOW
#P23 LOW
\ right motor
#P24 LOW
#P25 LOW
END
And run the following:
initpwm ok
driveahead ok
drivestop ok
turnright ok
drivestop ok
I have also tried
motor.FTH
initpwm ok
driveahead ok
drivestop ok
turnright ok
drivestop ok
While the motors turn, there is no signs of PWM on P26 and P27, they are 100% on all the time.
I have spent the last couple of days on this, tried the .24 Forth as well and older Extend.
Any suggestions?
many thanks
Lee
