Prop at 100mhz, what caps across vss and vdd?
I need to put some caps across the pwr leads of the 40pin dip prop.
I have access to some really cheap 10uf 6.3v tantalums.
Are these adequate? or is the 6.3v rating not high enough..
Should I use one of these also across pins 9 and 12 or am I ok
with just the one 10uf across 29 and 32...near the xtal?
Signature space for rent!
Send $1 to CannibalRobotics.com.
More info on caps here: http://www.allaboutcircuits.com/vol_1/chpt_13/4.html
Many seem to have no caps connected across the vdd-vss pairs. ?
So, does the prop usually work just fine even without these?
A new qfp prop board was just put up on gadget gangster for instance.
It has a 4.7uf 10v tantalum across vss-vdd pins 17 and 18 but no ceramic.
Vss-vdd at pins 27 and 30 seem to have no cap at all, and this is
the pair nearest the xtal pins.
The schematic does not show caps across any vss-vdd pair...it even
left off the 4.7uf that can be seen in the photo across 17,18.
Is it that only the dip prop needs these caps while the sm versions do not?
Post Edited (HollyMinkowski) : 4/9/2010 12:34:25 AM GMT
Is this "destruction" a stability problem alone or does it actually reduce the life expectancy of the chip? A few of my older designs did not have bypass caps on all Vdd's so I'm wondering if I should go back and try to solder a cap from the pin to the grounding plane.
Not everyone follows the best engineering practices. You've gotten good advice in this thread, though.
That part seems to be across BOEn and VDD not across VSS-VDD
Whatever it is it was left off the schematic.
qfp pins 5 and 8...the other vss-vdd pairs connect directly to +v and gnd.
ordered 100 cheap 1uf multilayer ceramics to try on my board...hopefully
that will be enough. I will place one very close to each set of pwr pins on
the 40 pin dip and see if it runs reliably at 100mhz. I will try it with and
without additional 10uf tantalums.
If you want to overclock, you really should also include the tantalum. It actually depends on what code you are running on the prop that determines the requirements and we cannot predict that so we should design for worst case.
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)·
· Prop OS: SphinxOS·, PropDos , PropCmd··· Search the Propeller forums·(uses advanced Google search)
My cruising website is: ·www.bluemagic.biz·· MultiBlade Props: www.cluso.bluemagic.biz
I don't know if the demoboard (propstick and protoboard have similar schematics) follow best practices, but I haven't had any problems with them or the Propeller Platform.
Propeller Forums RSS Feed!
Gadget Gangster - Share your Electronic Projects
The BOE line BTW is usually connected to ground so the pcb you saw would have the cap across VDD and GND. It is not necessary to place the big caps close to the Prop as they are mainly there to handle the "brown-outs" vs the "transients" that the fast X7R ceramics handle.
*Peter*
