BoeBot Control with MSRS
NWCCTV
With the attached code I am suppose to use the EBT 500 to connect the BoeBot and have MSRS control it. My question is this, can this code be modified to use a Comm port instead of a Bluetooth device? If so, how and where do I change it? Thanks in advance for any help.
So you do not want to use the EB500 for communication at all, but rather the programming port on the BASIC Stamp module to send and receive data?
Respectfully,
Joshua Donelson
www.parallax.com
' ========================================================================= ' ' File....... Axial and Reference Voltage ' Purpose.... Hitachi H48C 3-Axis Accelerometer (x6) Information gathering for LabVIEW ' Author..... Copyright (c) 2009-2010 Hot-n-Ready, Inc. ' E-mail..... Erick.Andino@gmail.com ' Started.... 02/17/10 ' ' {$STAMP BS2} ' {$PBASIC 2.5} ' ' ========================================================================= ' -----[noparse][[/noparse] Program Description ]--------------------------------------------- ' ' This program communicates with the accelerometer to gather information. ' ' -----[noparse][[/noparse] I/O Definitions ]------------------------------------------------- Dio PIN 15 ' data to/from module Clk PIN 14 ' clock output ' -----[noparse][[/noparse] Constants ]------------------------------------------------------- XAxis CON 0 ' adc channels YAxis CON 1 ZAxis CON 2 VRef CON 3 ' -----[noparse][[/noparse] Variables ]------------------------------------------------------- ax VAR Nib ' axis selection rvCount VAR Word ' ref voltage adc counts axCount VAR Word ' axis voltage adc counts cs VAR Word ' -----[noparse][[/noparse] Initialization ]-------------------------------------------------- DEBUG "con 00:0C:84:00:05:29",CR 'COM adress 'WAIT 5000 'Wait so the BlueTooth handshakes with PC ' -----[noparse][[/noparse] Program Code ]---------------------------------------------------- Main: SEROUT 16,16390, [noparse][[/noparse]"S"] 'Start character FOR cs = 8 TO 13 FOR ax = XAxis TO ZAxis ' loop through each axis 'Reset: HIGH cs ' deselect module 'Get_H48C ' read vRef & axis counts LOW cs SHIFTOUT Dio, Clk, MSBFIRST, [noparse][[/noparse]%11\2, VRef\3] ' select vref register SHIFTIN Dio, Clk, MSBPOST, [noparse][[/noparse]rvCount\13] ' read ref voltage counts HIGH cs 'PAUSE 1 LOW cs SHIFTOUT Dio, Clk, MSBFIRST, [noparse][[/noparse]%11\2, ax\3] ' select axis SHIFTIN Dio, Clk, MSBPOST, [noparse][[/noparse]axCount\13] ' read axis voltage counts HIGH cs '------------ IF (ax = 0) THEN 'DEBUG axis SEROUT 16, 16390, [noparse][[/noparse]"x"] ELSEIF (ax = 1) THEN SEROUT 16, 16390, [noparse][[/noparse]"y"] ELSEIF (ax = 2) THEN SEROUT 16, 16390, [noparse][[/noparse]"z"] ENDIF '------------ SEROUT 16, 16390,[noparse][[/noparse]"r"] SEROUT 16, 16390,[noparse][[/noparse]DEC5 rvCount] 'DEBUG vRef count SEROUT 16, 16390,[noparse][[/noparse]"a"] SEROUT 16, 16390,[noparse][[/noparse]DEC5 axCount] 'DEBUG vAxial count NEXT NEXT GOTO Mainericejah, that link does not work. Howecer, I do not want to spend any more money on this. Tryibg to do it witg parts I already have. Also, I will be using a wireless G adapter and VNC software to control and do not want to be using multiple wireless. Bluetooth has limited distance. I need to be able to control my robot from inside my home while the robot "patrols" outside. I have a high gain outdoor antenna to accomplish this.
Post Edited (NWCCTV) : 4/10/2010 4:42:19 AM GMT
- Stephen
Request_Connect:
··· pointer = RequestConnect
··· GOSUB Get_Packet
··· SEROUT 1, 84, [noparse][[/noparse]STR buffer \5]
· Confirm_Connect:
··· pointer = ConnectionGranted
··· Wait_For_Confirm:
····· SEROUT 1, 84, [noparse][[/noparse]255, 0, 1, 0, 0]
····· SERIN 0, 84, 20, Wait_For_Confirm, [noparse][[/noparse]WAITSTR buffer \ 2,
········································· buffer2, buffer3,
········································· buffer4]
· Request_Packet:
··· msgIndex = msgIndex + 1
··· pointer = RequestCommand
