Code Shrinking
Is there a way to make this code to execute faster?
It is gathering information okay but the cycle time is around 0.56 sec. Is not fast enough for my school project since I want to do some movement recognition with labview(r).
any help is really appreciated. thanks
' ========================================================================= ' ' File....... Axial and Reference Voltage ' Purpose.... Hitachi H48C 3-Axis Accelerometer (x6) Information gathering for LabVIEW ' Author..... Copyright (c) 2009-2010 Hot-n-Ready, Inc. ' E-mail..... Erick.Andino@gmail.com ' Started.... 02/17/10 ' ' {$STAMP BS2} ' {$PBASIC 2.5} ' ' ========================================================================= ' -----[noparse][[/noparse] Program Description ]--------------------------------------------- ' ' This program communicates with the accelerometer to gather information. ' ' -----[noparse][[/noparse] I/O Definitions ]------------------------------------------------- Dio PIN 15 ' data to/from module Clk PIN 14 ' clock output ' -----[noparse][[/noparse] Constants ]------------------------------------------------------- XAxis CON 0 ' adc channels YAxis CON 1 ZAxis CON 2 VRef CON 3 ' -----[noparse][[/noparse] Variables ]------------------------------------------------------- ax VAR Nib ' axis selection rvCount VAR Word ' ref voltage adc counts axCount VAR Word ' axis voltage adc counts cs VAR Word ' -----[noparse][[/noparse] Initialization ]-------------------------------------------------- DEBUG "con 00:0C:84:00:05:29",CR 'COM adress 'WAIT 5000 'Wait so the BlueTooth handshakes with PC ' -----[noparse][[/noparse] Program Code ]---------------------------------------------------- Main: DEBUG "S" 'Start character FOR cs = 8 TO 13 FOR ax = XAxis TO ZAxis ' loop through each axis 'Reset: HIGH cs ' deselect module 'Get_H48C ' read vRef & axis counts LOW cs SHIFTOUT Dio, Clk, MSBFIRST, [noparse][[/noparse]%11\2, VRef\3] ' select vref register SHIFTIN Dio, Clk, MSBPOST, [noparse][[/noparse]rvCount\13] ' read ref voltage counts HIGH cs 'PAUSE 1 LOW cs SHIFTOUT Dio, Clk, MSBFIRST, [noparse][[/noparse]%11\2, ax\3] ' select axis SHIFTIN Dio, Clk, MSBPOST, [noparse][[/noparse]axCount\13] ' read axis voltage counts HIGH cs '------------ IF (ax = 0) THEN 'DEBUG axis DEBUG "x" ELSEIF (ax = 1) THEN DEBUG "y" ELSEIF (ax = 2) THEN DEBUG "z" ENDIF '------------ DEBUG "r", DEC5 rvCount 'DEBUG vRef count DEBUG "a", DEC5 axCount 'DEBUG vAxial count NEXT NEXT GOTO Main
"puff"...... Smile, there went another one.
If you really MUST send that data, use "SEROUT 16" and select a faster baud rate, and send only what you need to send.
Post Edited (erickejah) : 4/9/2010 2:19:42 PM GMT
