PPDB Rev A - 5V Regulator issue..I think
Using the PPDB Rev A, haven't used it in a bit. I was using it fine with a 12V wall wart.
Anyhow, "No Chip Found" message from PropTool, and I looked at the Regulators, all around the 5V Reg is yellow/brownish, I touched the 5V reg and OUCH!.
And the DIP Prop is also very hot....
I switched to an 8V wall wart, let things cool down and still no prop found, the power LED on the PPDB stays on for a couple secs but then goes out, the Reg and Prop still get very hot.
Suggestions?
PrEditor·- Text Editor
NYC Area Prop Club
Suggestions?
NYC Area Prop Club
NYC Area Prop Club
If it is a long dissused board, has it·suffered a solder splat ?
Style and grace : Nil point
T o n y
But I placed another propdip in after measuring a crisp 5V of that Reg and 3.3 of the other, and it works fine.
Maybe the prior propdip was put in backwards?
NYC Area Prop Club
There is a tantalum input capacitor on the PPDB, which is sensitive to overvoltage. Sometimes linear power supplies will output much more than their intended voltage when the current draw is low. The PPDB, in and of itself, doesn't draw much power, so your supply might have overvoltaged the input capacitor. Since it is a tantalum capacitor, it will very thoroughly destroy itself when the voltage is to high. (I have had them catch on fire before.) They usually end up shorting after they are destroyed, so chances are that your Propeller is unaffected, but your regulator's input is now shunted to ground. You may be able to continue using your PPDB by supplying regulated 5 VDC into the "5V" pins.
— David Carrier
NYC Area Prop Club
I guess that is not your issue though but responding to and supporting David's warning. Be careful of what voltage you actually put into the board.
Or replace the cap.
