Setting DAT values — Parallax Forums
Setting DAT values
BeanBean Posts: 8,129
edited 2010-04-07 13:45 in Propeller 1
In PASM if you have:
value1··· LONG 1024
value2··· LONG value1
It sets value2 to the ADDRESS of value1, not it's value. Is there any way to get the value ? Some kind of prefix or something ?
Bean
Use BASIC on the Propeller with the speed of assembly language.
PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
March 2010 Nuts and Volts article·http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp5.pdf
There are two rules in life:
· 1) Never divulge all information
  • RaymanRayman Posts: 16,460
    edited 2010-04-07 13:18
    I was caught by that once before too...
    I don't think there is any way to do it...
    I just use the CON section to make constant parameters for the DAT section...
    My Prop Products:· http://www.rayslogic.com/Propeller/Products/Products.htm
    The value of any label like "value1" or "value2" in PASM is always its address in the cog. As Rayman mentioned, you can explicitly define a label to have any value by using a CON section. You can't get the content of a memory location at compile/assembly time. The compiler/assembler doesn't keep that information around. It generates the data into the object file and that's that.
