Voltage sensor
i need to sense voltage across a batteyr. it will be limited between 32V and 42V. i need a circuit which will sense this voltage across the battery(a differential amp ckt kinda thing) and then scale it to 0 to 10V so as to give to FPGA.
so do i need two opamp stages? 1 with diffeential opamp mode , and then a scaling or amplifying stage?
the differential mode to sense the battery across the two terminals of the battery is a must, i cant make out how to accomplish.Pleaase help me.
"puff"...... Smile, there went another one.
2) Most differential amplifiers still have a limit on the maximum voltage relative to ground that they can handle without damage and 32-42V is on the high range. A simple passive voltage divider (1:4 or 1:5) could reduce this to a more reasonable range (like 6-8V), then one op-amp stage could remove the bias (6V) and a second stage could provide fixed amplification to bring it back to a 0-10V range. You'd probably need a regulated +12V supply for the op-amps.
