PMB-248 GPS gives only GGA sentences
carlosg
I want to get true heading information from this GPS as in $GPHDT sentences
but it only gives $GPGGA sentences.· If I·issue a request as follows:
$CCGPQ,HDT\r\n
I would expect it to give HDT sentences but instead I no longer get anything back.
Anyone know if this should work?
$CCGPQ,HDT\r\n
As far as I know this sentence is not available on this unit.
Massimo
You know of any sentence that will give heading on this unit?
I also tried RMC·but nothing.
Wish I had a list of sentences it supports.·
The spec only states NMEA and the website states NMEA0183 v2.2
I've just started with this and so was not moving at the time --
I assumed it would just give a bogus value.
Could it be·it actually needs to be moving in some direction?
Carlos
RMC will give true course over ground when moving.
John Abshier
Massimo
Got it from here http://www.cs.put.poznan.pl/wswitala/download/pdf/NMEAdescription.pdf
which describes the NMEA 0183 protocol.
I figured the chip has an RX pin for something!
Sounds like I'll only get RMC when I get moving. Thanks all for the pointers.
Carlos
I have spent many hours searching for code to program the optional baud rates and·features, without even a hint that the GPS will accept data. I just figured The "optional" is programed at the factory with propriatary code.
Yes, Polstar·docs could use a little improvment.
Jim
·· RMC will give true course over ground when moving.
·· John Abshier]
John,· at walking pace, I still do not get RMC.· Do you know how fast it needs to be moving?
I'm thinking of calculating heading my self over a span of a few seconds of lat/long. data.
Carlos
·· John Abshier]
Carlos
I've tested the parser with a GPS simulator without problem.
I did encounter giberish characters with the GPS chip but no problem,
I ignore everything until I read a $
Carlos
So my code, timing, or something I'm introducing is to blame so I'll investigate further.
Thanks all for the help and suggestions!
