Analog Input on BS2pe w/28301 daughterboard
How do you perform analog input on the bs2pe?· I have the 28301 daughterboard, which I think is required, and a LM34 temperature sensor.· How do I take a reading from the LM34?· What pin do I connect it to?· A0,A1,A2,A3?· Did I even need the 28301 daughterboard (the I/O daughterboard)?· I have been told I need to use something called the AVR, but that doesn't seem to be mentioned anywhere in the programming manual.·
A: See the documentation for the GPIO3 coprocessor firmware, which is preinstalled on the MoBo.
Q: How do I take a reading from the LM34?
A: Connect V+ to Vdd, Gnd to Vss, and Vout to the coprocessor input.
Q: What pin do I connect it to? A0,A1,A2,A3?
A: Either A0 or A1.
Q: Did I even need the 28301 daughterboard (the I/O daughterboard)?
A: No. You could have used the Proto-DB, which is less expensive and provides holes to solder the sensor into. (I don't recommend poking component leads directly into the daughterboard sockets, though.)
Q: I have been told I need to use something called the AVR, but that doesn't seem to be mentioned anywhere in the programming manual.
A: The PBASIC manual does not cover AVR programming. The AVR firmware driver docs are listed with their respective daughterboards. But the default GPIO3 is what you want to use.
Here is my function, GetReading:
GetReading:
OWOUT Owio, 0, [noparse][[/noparse]%00001011]
DO
OWIN Owio, 4, [noparse][[/noparse]Busy]
LOOP WHILE Busy
OWIN Owio, 0, [noparse][[/noparse]Voltage.HIGHBYTE, Voltage.LOWBYTE]
DEBUG DEC Voltage
RETURN
When I run this function repeatedly in a loop, the value bounces around a bit then settles on Voltage=390. I change the test voltage to 0v (ground) and the reading remains the same. What am I doing wrong? Thanks!
Please list your entire program between [noparse][[/noparse]code] and [noparse][[/noparse]/code] tags.
