Fried PropStick
TheGrue
Some how I think I fried my PropStick. I was building the attached Schematic for a Robot Remote Controller unit. I had wired up the XBee and Accelerometer on a breadboard for testing and all was well. I finished my board and tested each connection after I soldered it. I have not attached the switches or the LED's in the circuit. I just wired the resistors with jumper connectors for the front panel. The voltage regulator on the chip is putting out 4.5V without the USB attached and 5.5V with the USB adapter plugged into the PropStick. When it was on the breadboard it was a nice 3.3V
Can anyone see something in my schematic that might fry a PropStick? I would greatly appreciate a second pair of eyes.
Diagnostic Procedure followed:
After I could not get the PropStick to be recognized by the Propeller Tool for programming, I removed the Accelerometer, XBee and PropStick from my board. I tested all of the parts as follows> The accelerometer on a Demo Board = works fine. The XBee on the Parallax XBee USB adapter and was able to query the XBee with the X-CTU software and got a response from the XBee = works. Put PropStick back into a breadboard and applied a 6V battery to the VSS/GND and VIN making sure of the correct polarity of course. The Prop Tool could not find a Propeller. Tried several USB cables and ports, I even restarted my computer. I checked pin 32/VDD for the 3.3V output and saw the high voltages listed above.
Post Edited (TheGrue) : 4/5/2010 6:32:22 AM GMT
First of al - On SCH --- You have reversed BAT Voltage
Regards
Ps. VIN-VCC is always +
GND always -
Nothing is impossible, there are only different degrees of difficulty.
For every stupid question there is at least one intelligent answer.
Don't guess - ask instead.
If you don't ask you won't know.
If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
Sapieha
Post Edited (Sapieha) : 4/5/2010 4:55:18 AM GMT
Vin (PropStick pin 12) is the input to the built-in 3.3V regulator and can be connected to any source of 5-9V.
Vss (PropStick pins 9, 10, and 29) is ground. All 3 Vss pins must be connected to ground.
Vss pin 29 doesn't seem to be connected on your schematic and needs to be.
One of the Vss pins on the xBee board isn't connected and probably needs to be.
Other than that, I don't see anything obviously wrong with your schematic.
You didn't include details on the USB adapter. I assume that you're using the built-in USB adapter on the PropStick.
Most likely you made some kind of error and your schematic doesn't reflect what's actually connected.
Post Edited (Mike Green) : 4/5/2010 5:21:04 AM GMT
Consider calling Parallax Tech Support tomorrow. They may have you send the PropStick back for testing. They're pretty good about replacing things.
Thanks again!
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" 16:9 LCD Composite video display, eProto for SunSPOT, PropNET, PolkaDOT-51
www.tdswieter.com
