Driving a coil
Hello,
I am in need of a method to drive a small pancake coil (10mm diameter) with the prop. I was thinking of using a npn transistor to drive the coil from a pin. Do I need a diode to protect from back emf? I have used a 555 timer with a transistor and I would like to use the prop and the synth object to get any square wave. Thanks for any suggestions.
Curtis
Curtis
Switch on, for a period, and then off again as a single act, or ...
On and off continuously at a certain frequency ( posibly resonant ) ?
For the first a quick reverse diode will be ok, but for the second the resonance shouldn't be damped and the transistor will have to be selected to withstand the peak voltages.
Style and grace : Nil point
I would like to use the prop pin to continuosly excite apancake coil. I would like to be able to use different frequencies with no capacitor (RL circuit). Probably not at resonance. I was thinking of connecting the prop pin to one lead of the coil and then the other coil lead to ground via a resistor (RL circuit). Would the reverse diode be between the prop pin and the coil lead? I will experiment with this today. I just wanted to protect my prop. Any suggestions would be great.
Curtis
If the resistance is large the the tendancie to resonate would be reduced but without knowing the coils parameters or the intended frequencies, I would be protective of the Prop to start with and get measurements of the voltages and currents generated.
That extra transistor would provide an extra stage of protection.
Post Edited (Toby Seckshund) : 4/5/2010 6:38:05 PM GMT
The trick is to drive the GROUND leg of your inductive load. Hook the other end of anything from a motor to a magnetic coil up to any voltage up to the rated voltage of the transistor. I've gone as high as 24 volts with no problems and higher shouldn't be a problem either. They aren't as FAST as some newer transistors, but are easy and cheap. You can use resistors of 1-10K between the base and the propeller which gives some further protection.
Ken B.
" Anything worth doing... is worth overdoing. "
··············································· ( R.A.H. )
