Dual Voltage Power Supply + PE Kit
Whit
Hey all,
I picked up one of Brian's (http://ucontroller.com/index.html)·Dual Voltage Power Supply Kits to use with my Propeller Education Kit. It supplies 5 volts and 3.3 volts to a breadboard and uses a Parallax standard 2.1 mm center positive connection to a 7-9 volt wall wart. I includes and on/off switch and an LED to indicate when it is on. There are alterative pin location to adapt to breadboard variations.
The PCB boards are very nice and screened clearly. The documentation is simple and clear and it is a cinch to put together. I don't know if I got lucky, but mine is dead on. The 5 volt side provide 5.000 volts and the 3.3 volt side provided 3.305 volts. Can't beat that.
It is a nice little kit and sure beats using 9 volt batteries! My son even helped me put it together and learned about the parts, how to place them and got to watch so soldering.
(Pic is from ucontroller.com)
Whit+
Post Edited (Whit) : 4/2/2010 8:28:58 PM GMT
Whit+
