Homework board will not power on
I have a basic stamp homework board and after entering the END command, it for some reason refuses to power on. I've tried half a dozen batteries and connected it directly to a variable wall transformer and all I can get out of it is a brief flicker of the run LED when I press reset. The board will not communicate with the computer either, a problem I had immediately before the board shut down. Any ideas? I was controlling two small 6v DC motors and everything was going fine (once I got the board up and running) until I got tired of the whirring gears and stopped it...
It's possible something has happened with the connection between the Homework Board and the PC. Make sure you get +5V across Vdd/Vss. The Stamp has to be powered and running (then reset) for it to communicate with the PC.
From the command pin to Vss, each motor will remain on continuously and from Vdd to Vss I'm reading 6.3-6.5v. Could it be stuck in a loop? Maybe something has shorted on the board?
C-Bob
Every problem·have at least one·nice, simply and·wrong solution.
Post Edited (C-Bob) : 4/2/2010 4:52:09 PM GMT
It sounds like there might be some readings (voltages) that you shouldn't be getting on your HWB; if you would like to have the HomeWork Board tested, please contact Technical Support to set up an RMA. You can use the following number to contact us; also if you can have your customer number with you when you call, just makes the process that much easier.
·Parallax Technical Support : 888-997-8267
Respectfully,
Joshua Donelson
www.parallax.com
