AT45DB161D ,,,,,,SOS. interface to prop
Hi guys I hate to be a pain but I have been working on trying to get my prop to read and write to this chip can anyone help me I tired using the DS1620 interface as a sort of guide I even found a driver in Obex but no matter what I try I can not get anything out of it, What I could really use is just a simple program that would tell me if I have it interfaced correctly I am attaching the data sheet and the driver I tried I actually have a few SPI flash rams of different brands so I would really appreciate and knowledge that will help me understand how to read and write to this type of device
even a quick interface circuit would be a huge help
Attached is a program I wrote to interface with the Atmel DF chips.
Although I still use the DF chips, I haven't used this program in a while. It was the simplest, most stand alone things I could find easily. There are lots of comments (hopefully some of them correct). The programing style isn't great (it was one of my early spin/asm programs; hopefully I've gotten a bit better since then). There a number of spin methods at the top that cause PASM routines to be run. I suggest you start with RESET_CHIP and READ_STATUS_REGISTER.
There are constants at the front which control which lines to use. There is also a constant called MY_CHIP. I had 5 of these on one board so that constant allowed me to run this program on one particular chip.
I'm sure you'll have questions about it. I certainly do. So post back here and I'll try to help.
Peter
FYI- DON'T USE THE CHIP ERASE FUNCTION. At least in the version I purchased it doesn't work. There's one line in the errata that says it may not work correctly. Well it doesn't work at ALL.
I found a spin only version that might be easier to understand (but slower). Both programs use FullDuplexSerial and Numbers.
P0-P1-P2
I connected to the Sram like this see attached I did use a 10K pullup and I also tried running your example and tracing prop pins with my scope but no cigar as they say
Have you tried the spin code (DataFlashCommands.spin). I think it's all in spin so it should be easier to follow. Let me know if you have questions about it.
p
The example has:
PUB main ' ...
start(8,9,0,0) ' this says use P8 for clock, P9 for chip select, and P0 for data in and data out
PUB start(pck, pcs, pdi, pdo) ' the method is defined like this
Your pin settings description is not clear.
If you have P0 for clock, P1 for chip-select, and P2 for data in and data out, use this:
start(0,1,2,2)
May the road rise to meet you; may the sun shine on your back.
May you create something useful, even if it's just a hack.
